Community Member
Cannot ping Serial interfaces T1 card
Cannot ping serial interfaces. Cable type is T1 crossover.
cARD type - WIC T1 DSU/CSU - version 1
Router 1 - 2611XM
interface Serial0/0
no ip address
no fair-queue
service-module t1 clock source internal
interface Serial0/0.1
ip address 172.23.2.138 255.255.255.252
Router 2 - 2620
interface Serial0/0
no ip address
ip address 172.23.2.137 255.255.255.252
Router 2
#sh interfaces s0/0
Serial0/0 is up, line protocol is up
  Hardware is PQUICC with Fractional T1 CSU/DSU
  MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
  Encapsulation HDLC, loopback not set
  Keepalive set (10 sec)
  Last input 00:00:01, output 00:00:04, output hang never
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/1/256 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 1158 kilobits/sec
  5 minute inpud rate 0 bits/sec, 0 packets/sec
     46 packets input, 5340 bytes, 0 no buffer
     Received 34 broadcasts, 0 runts, 0 giants, 0 throttles
     48 input errors, 47 CRC, 1 frame, 0 overrun, 0 ignored, 0 abort
     33 packets output, 4656 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     1 carrier transitions
     DCD=up  DSR=up  DTR=up  RTS=up  CTS=up
Router 1
#sh interfaces ser0/0
  MTU 1500 bytes, BW 1536 Kbit/sec, DLY 20000 usec,
  Last input 00:00:04, output 00:00:01, output hang never
  Queueing strategy: fifo
  Output qeeue: 0/40 (size/max)
     41 packets input, 5492 bytes, 0 no buffer
     Received 41 broadcasts, 0 runts, 0 giants, 0 throttles
     2 input errors, 0 CRC, 2 frame, 0 overrun, 0 ignored, 0 abort
     58 packets output, 6422 bytes, 0 underruns
     0 output errors, 0 collisions, # interface resets
     2 unknown protocol drops
Router 1#ping 172.23.2.137
Sending 5, 100-byte ICMP Echos to 172.23.2.137, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Router 1
sisrtdnc2a#sh controllers
Interface FastEthernet0/0
Hardware is AMD Am79c977
ADDR: 8493D2AC, FASTSEND: 8010FB00, MCI_INDEX: 0
DIST ROUTE ENABLED: 0
Route Cache Flag: 11
LADRF=0x0000 0x0100 0x0000 0x0000
CSR0  =0x00000004, CSR3  =0x00000004, CSR4  =0x00000804, CSR15 =0x00000000
CSR80 =0x00001800, CSR114=0x00000000, CRDA  =0x00000000, CXDA  =0x00000000
BCR9 =0x00000000
CSR5  =0x00000000, CSR7  =0x00008008, CSR100=0x00000000, CSR125=0x00005C3C
BCR2  =0x00001000, BCR9  =0x00000000, BCR18 =0x00001880, BCR22 =0x00001818
BCR25 =0x00000200, BCR26 =0x00000100, BCR27 =0x00000000, BCR32 =0x00004D80
HW filtering information:
  Promiscuous Mode Disabled, PHY Addr Enabled, Broadcast Addr Enabled
  PHY Addr=000F.9093.7580, Multicast Filter=0x0000 0x0100 0x0000 0x0000
amdp2_instance=0x8493E374, registers=0x40000000, ib=0x5D75760
rx ring entries=64, tx ring entries=128
rxring=0x5D757C0, rxr shadow=0x8493E92C, rx_head=0, rx_tail=0
txring=0x5D75C00, txr shadow=0x8493EA60, tx_head=0, tx_tail=0, tx_count=0
Software MAC address filter(hash:length/addr/mask/hits):
need_af_check = 0
  0x00:  0  ffff.ffff.ffff  0000.0000.0000         0
  0xC0:  0  0100.0ccc.cccc  0000.0000.0000         0
spurious_idon=0, throttled=0, enabled=0, disabled=0
rx_framing_err=0, rx_overflow_err=0, rx_buffer_err=0
rx_bpe_err=0, rx_soft_overflow_err=0, rx_no_enp=0, rx_discard=0
tx_one_col_err=0, tx_more_col_err=0, tx_no_enp=0, tx_deferred_err=0
tx_underrun_err=0, tx_late_collision_err=0, tx_loss_carrier_err=0
tx_exc_collision_err=0, tx_buff_err=0, fatal_tx_err=0
hsrp_conf=0, need_af_check=0
tx_limited=0(64)
PHY registers:
  Register 0x00:   1C00  7809  0013  78E2  01E1  0000  0004  2001
  Register 0x08:   0000  FFFF  FFFF  FFFF  FFFF  FFFF  FFFF  FFFF
  Register 0x10:   2104  0100  0000  0014        0000  0000  0000
  Register 0x18:   0000  0000  0048  0000  FFFF
router 1
#sh controllers serial 0/0
Interface Serial0/0
Hardware is PowerQUICC MPC860 with Integrated FT1 CSU/DSU module
TX and RX clocks detected.
idb at 0x849490D8, driver data structure at 0x849507FC
SCC Registers:
General [GSMR]=0x2:0x00000030, Protocol-specific [PSMR]=0x8
Events [SCCE]=0x0000, Mask [SCCM]=0x001F, Status [SCCS]=0x06
Transmit on Demand [TODR]=0x0, Data Sync [DSR]=0x7E7E
Interrupt Registers:
Config [CICR]=0x00367F80, Pending [CIPR]=0x04000800
Mask   [CIMR]=0x20200400, In-srv  [CISR]=0x00000000
Command register [CR]=0x640
Port A [PADIR]=0x0000, [PAPAR]=0xFFFF
       [PAODR]=0x0000, [PADAT]=0xBBFB
Port B [PBDIR]=0x0220F, [PBPAR]=0x0000E
       [PBODR]=0x00000, [PBDAT]=0x3DDDD
Port C [PCDIR]=0x00C, [PCPAR]=0x000
       [PCSO]=0x080,  [PCDAT]=0xF30, [PCINT]=0x00F
Receive Ring
        rmd(680127F0): status 9000 length 1A address 5E1C764
        rmd(680127F8): status 9000 length 1A address 5E1CDE4
        rmd(68012800): status 9000 length 15B address 5E13EE4
        rmd(68012808): status 9000 length 15D address 5E131E4
        rmd(68012810): status 9000 length 1A address 5E13864
        rmd(68012818): status 9000 length 1A address 5E14564
        rmd(68012820): status 9000 length 1A address 5E14BE4
        rmd(68012828): status 9000 length 1A address 5E15264
        rmd(68012830): status 9000 length 1A address 5E158E4
        rmd(68012838): status 9000 length 1A address 5E15F64
        rmd(68012840): status 9000 length 15B address 5E165E4
        rmd(68012848): status 9000 length 15D address 5E16C64
        rmd(68012850): status 9000 length 1A address 5E172E4
        rmd(68012858): status 9000 length 1A address 5E17964
        rmd(68012860): status 9000 length 1A address 5E17FE4
        rmd(68012868): status 9000 length 1A address 5E18664
        rmd(68012870): status 9000 length 1A address 5E18CE4
        rmd(68012878): status 9000 length 1A address 5E19364
        rmd(68012880): status 9000 length 15B address 5E199E4
        rmd(68012888): status 9000 length 15D address 5E1A064
        rmd(68012890): status 9000 length 1A address 5E1A6E4
        rmd(68012898): status 9000 length 1A address 5E1AD64
        rmd(680128A0): status 9000 length 1A address 5E1B3E4
        rmd(680128A8): status B000 length 1A address 5E1C0E4
Transmit Ring
Head: 3, tail: 3
        tmd(680128C8): status 5C00 length 68 address 5C53714 Int.last.TxCRC.
        tmd(680128D0): status 5C00 length 68 address 5E28834 Int.last.TxCRC.
        tmd(680128D8): status 5C00 length 68 address 5E27BB4 Int.last.TxCRC.
        tmd(680128E0): status 5C00 length 68 address 5C53D54 Int.last.TxCRC.
        tmd(680128E8): status 5C00 length 18 address 5E26DF4 Int.last.TxCRC.
        tmd(680128F0): status 5C00 length 44 address 5E285B4 Int.last.TxCRC.
        tmd(680128F8): status 5C00 length 44 address 5C53FD4 Int.last.TxCRC.
        tmd(68012900): status 5C00 length 44 address 5E26B74 Int.last.TxCRC.
        tmd(68012908): status 5C00 length 18 address 5C53E94 Int.last.TxCRC.
        tmd(68012910): status 5C00 length 44 address 5E27F74 Int.last.TxCRC.
        tmd(68012918): status 5C00 length 18 address 5E26F34 Int.last.TxCRC.
        tmd(68012920): status 5C00 length 14C address 5E2A9F4 Int.last.TxCRC
        tmd(68012928): status 7C00 length 14E address 5E2B0D4 Wrap.Int.last.
C.
        tmd(680128B0): status 5C00 length 18 address 5C53714 Int.last.TxCRC.
        tmd(680128B8): status 5C00 length 18 address 5C54B14 Int.last.TxCRC.
        tmd(680128C0): status 5C00 length 18 address 5C54ED4 Int.last.TxCRC.
tx_limited=0(16)
SCC GENERAL PARAMETER RAM (at 0x68013D00)
Rx BD Base [RBASE]=0x27F0, Fn Code [RFCR]=0x18
Tx BD Base [TBASE]=0x28B0, Fn Code [TFCR]=0x18
Max Rx Buff Len [MRBLR]=1548
Rx State [RSTATE]=0x18008440, BD Ptr [RBPTR]=0x28A8
Tx State [TSTATE]=0x18000548, BD Ptr [TBPTR]=0x28C8
SCC HDLC PARAMETER RAM (at 0x68013D38)
CRC Preset [C_PRES]=0xFFFF, Mask [C_MASK]=0xF0B8
Errors: CRC [CRCEC]=0, Aborts [ABTSC]=0, Discards [DISFC]=0
Nonmatch Addr Cntr [NMARC]=0
Retry Count [RETRC]=0
Max Frame Length [MFLR]=1610
Rx Int Threshold [RFTHR]=0, Frame Cnt [RFCNT]=65465
User-defined Address 0000/0000/0000/0000
User-defined Address Mask 0x0000
buffer size 1524
PowerQUICC SCC specific errors:
0 input aborts on receiving flag sequence
0 throttles, 0 enables
0 overruns
0 transmitter underruns
0 transmitter CTS losts
0 aborted short frames
Router 2
#sh controllers s0/0
Interface Serial0/0
idb at 0x81E8F3DC, driver data structure at 0x81E971B0
SCC Registers:
General [GSMR]=0x2: x00000030, Protocol-specific [PSMR]=0x8
Config [CICR]=0x00367F80, Pending [CIPR]=0x04008000
Mask   [CIMR]=0x40204000, In-srv  [CISR]=0x00000000
Command register [CR]=0x600
       [PAODR]=0x0000, [PADATM=0xEEFF
Port B [PBDIR]=0x0180F, [PBPAR]=0x0000E
       [PBODR]=0x00000, [PBDAT]=0x3E77D
       [PCSO]=0x020,  [PCDAT]=0xFC0, [PCINT]=0x00F
Receive Ring
        rmd(680126B0): status 9000 length 1A address 3B6D7A4
        rmd(680126B8): status 9000 length 46 address 3B6DE24
        rmd(680126C0): status 9000 length 1A address 3B6E4A4
        rmd(680126C8): status )000 length 14E address 3B6EB24
        rmd(680126D0): status 9000 length 150 address 3B6F1A4
        rmd(680126D8): status 9000 length 1A address 3B6F824
        rmd(680126E0): status 9000 length 1A address 3B6FEA4
        rmd(680126E8): status 9000 length 1A address 3B662A4
        rmd(680126F0): status 9000 length 1A address 3B66924
        rmd(680126F8): status 9000 length 46 address 3B66FA4
        rmd(68012700): status 9000 length 46 address 3B67624
        rmd(68012708): status 9000 length 1A address 3B67CA4
        rmd(68012710): status 9000 length 46 address 3B68324
        rmd(68012718): status 9000 length 46 address 3B689A4
        rmd(68012720): status 9000 length 1A address 3B69024
        rmd(68012728): status 9000 length 14E address 3B69D24
        rmd(68012730): status 9000 length 15  address 3B6A3A4
        rmd(68012738): status 9000 length 1A address 3B6AA24
        rmd(68012740): status 9000 length 1A address 3B6B0A4
        rmd(68012748): status 9000 length 1A address 3B6B724
        rmd(68012750): status 9000 length 1A address 3B6BDA4
        rmd(68012758): status 9000 length 46 address 3B6C424
        rmd(68012760): status 9000 length 46 address 3B6CAA4
        rmd(68012768): status B000 length $6 address 3B6D124
Transmit Ring
        tmd(68012770): status 5C00 length 18 address 3A00494
        tmd(68012778): status 5C00 length 18 address 3A00854
        tmd(68012780): status 5C00 length 18 address 3A00E94
        tmd(68012788): status 5C00 length 18 address 3A01394
        tmd(68012790): status 5C00 length 159 address 3C8C554
        tmd(68012798): status 5C00 length 1%B address 3C8CC34
        tmd(680127A0): status 5C00 length 18 address 3A000D4
        tmd(680127A8): status 5C00 length 18 address 3C81C94
        tmd(680127B0): status 5C00 length 18 address 3C82054
        tmd(680127B8): status 5C00 length 18 address 3C82414
        tmd(680127C0): status 5C00 length 18 address 3C82B94
        tmd(680127C8): status 5C00 length 18 address 3C82E14
        tmd(680127D0): status 5C00 length 159 address 3C8D314
        tmd(680127D8): status 5C00 length 15B address 3C8D9F4
        tmd(680127E0): status 5C00 length 18 address 3C83314
        tmd(680127E8): status 7C00 length 18 address 3C836D4
tx_limited=1(2)
SCC GENERAL PARAMETER RAM (at 0x68013C00)
Rx BD Base [RBASE]=0x26B0, Fn Code [RFCR]=0x18
Tx BD Base [TBASE]=0x2770, Fn Code [TFCR]=0x18
Rx Stade [RSTATE]=0x18008440, BD Ptr [RBPTR]=0x2728
Tx State [TSTATE]=0x18000548, BD Ptr [TBPTR]=0x27A0
SCC HDLC PARAMETER RAM (at 0x68013C38)
Errors: CRC [CRCEC]=47, Aborts [ABTSC]=0, Discards [DISFC]=0
Max Frame Length [MFLR]=1608
Rx Int Threchold [RFTHR]=0, Frame Cnt [RFCNT]=65353
buffer size 1524
0 overruns
Green
You are seeing CRC errors for almost every frame.
I think you will need to set ONE end as
interface Serial0/0
service-module t1 clock source line
Can you try and retest.
Alex
Regards, Alex. Please rate useful posts.
Re: Cannot ping Serial interfaces T1 card
Are these routers connected back to back?
I see a lot of CRC errors on the R1 serial interface, although the serial interface up. Did you try clearing the interfaces? What happens if you change the encapsulation on the interface to say PPP, does it make any difference.
Try changing the cable as well.
Hall of Fame Super Gold
In addition to the possibility that there is a clocking issue I believe that there is another problem with this configuration. The interfaces are configured to use the default encapsulation of HDLC and use subinterfaces. But to my knowlede HDLC does not support subinterfaces. I would be very interested in seeing the output of show ip route from either (or both) of the routers. I suspect that the router does not have the IP address as a connected subnet.
Rick
515
