cant add t-1 to VWIC-2MFT-T1-DI
jerry.mcrae
i googled the error message but didnt find any useful information. any one ever had this issue before? i lowed the max sessions for conference and transcoding but with no luck. i also maxed out pvdm on the network module (NM-HDV)
EWT_NOC(config)#controller T1 1/1
EWT_NOC(config-controller)#channel-group 0 timeslots 1-24 speed 64
Channel setup failed!!! s:t:c 1:1:0
HDV slot 1 DRAM size 524280 free 66725 need 124992
%Insufficient resources to create channel group
thanks in advance.
gearnsc
"HDV slot 1 DRAM size 524280 free 66725 need 124992 "
It appears that you don't have enough ram to allocate to the interface. Check to ensure SMARTinit is enabled. SMARTinit automatically adjusts interface memory allocations on router boot.
Router(config)#no memory-size iomem
Smart-init will be enabled upon reload.
If this doesn't solve the problem you'll probably need to buy additional RAM for your router.
i'll try it and post the results.
thanks!
