cant add t-1 to VWIC-2MFT-T1-DI
i googled the error message but didnt find any useful information. any one ever had this issue before? i lowed the max sessions for conference and transcoding but with no luck. i also maxed out pvdm on the network module (NM-HDV)
EWT_NOC(config)#controller T1 1/1
EWT_NOC(config-controller)#channel-group 0 timeslots 1-24 speed 64
Channel setup failed!!! s:t:c 1:1:0
HDV slot 1 DRAM size 524280 free 66725 need 124992
%Insufficient resources to create channel group
thanks in advance.
Re: cant add t-1 to VWIC-2MFT-T1-DI
"HDV slot 1 DRAM size 524280 free 66725 need 124992 "
It appears that you don't have enough ram to allocate to the interface. Check to ensure SMARTinit is enabled. SMARTinit automatically adjusts interface memory allocations on router boot.
Router(config)#no memory-size iomem
Smart-init will be enabled upon reload.
If this doesn't solve the problem you'll probably need to buy additional RAM for your router.
i'll try it and post the results.
thanks!
428
