Cant ping spoke to spoke IPSEC/GRE Deployment
Mark Rigby
Greetings,  i have a hub and spoke IPSEC/GRE configuration connecting together 5 routers. I can ping from spoke to spoke when connected to each spoke router but if i add the inside interface as the source address i cant ping between spokes.
I think it may be a NAT or Crypto issue but any assistance would be much appreciated, yes i could create seperate tunnels between spokes or use DMVPN but the customer wants all traffic to go via the HUB site.
Ping another spoke router
#ping 192.168.20.1
Sending 5, 100-byte ICMP Echos to 192.168.20.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 120/123/124 ms
Traceroute to another spoke router
#traceroute 192.168.20.1
Tracing the route to 192.168.20.1
  1 10.255.255.13 56 msec 56 msec 52 msec
  2 10.255.255.2 116 msec *  116 msec
Ping another spoke router with source-interface statement
#ping 192.168.20.1 source vlan 1
Packet sent with a source address of 192.168.50.1
Success rate is 0 percent (0/5)
Show IP Route on spoke router with LAN IP 192.168.50.1
bhx-ro-877#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
D    192.168.30.0/24 [90/2882560] via 10.255.255.13, 01:35:17, Tunnel0
     81.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C       81.**.**.**/32 is directly connected, Dialer1
C       81.**.**.**/24 is directly connected, Dialer1
D    192.168.10.0/24 [90/1602560] via 10.255.255.13, 02:46:54, Tunnel0
D    192.168.40.0/24 [90/2882560] via 10.255.255.13, 02:46:54, Tunnel0
D    192.168.20.0/24 [90/2882560] via 10.255.255.13, 02:46:54, Tunnel0
     10.0.0.0/30 is subnetted, 4 subnets
D       10.255.255.8 [90/2880000] via 10.255.255.13, 02:46:54, Tunnel0
C       10.255.255.12 is directly connected, Tunnel0
D       10.255.255.0 [90/2880000] via 10.255.255.13, 02:46:54, Tunnel0
D       10.255.255.4 [90/2880000] via 10.255.255.13, 02:46:54, Tunnel0
C    192.168.50.0/24 is directly connected, Vlan1
S*   0.0.0.0/0 is directly connected, Dialer1
Crypto Map and Tunnel Interface on Spoke Router - 192.168.50.1
interface Tunnel0
bandwidth 8000
ip address 10.255.255.14 255.255.255.252
ip mtu 1420
ip nbar protocol-discovery
qos pre-classify
tunnel source Dialer1
tunnel destination 81.**.**.**
tunnel path-mtu-discovery
crypto map cryptomap
crypto map cryptomap 1 ipsec-isakmp
description ****** Link to HUB ******
set peer 81.**.**.**
set security-association lifetime seconds 86400
set transform-set 3DesL2L
set pfs group2
match address 101
access-list 100 remark ****** NAT ACL ******
access-list 100 deny   ip 192.168.50.0 0.0.0.255 192.168.0.0 0.0.255.255
access-list 100 deny   ip 192.168.50.0 0.0.0.255 172.31.255.0 0.0.0.255
access-list 100 permit ip 192.168.50.0 0.0.0.255 any
access-list 101 remark ****** Link to hqhnswth-ro-877 ******
access-list 101 permit ip 192.168.50.0 0.0.0.255 192.168.0.0 0.0.255.255
route-map nonat permit 1
match ip address 100
ip nat inside source route-map nonat interface Dialer1 overload
router eigrp 1
passive-interface Dialer1
passive-interface Vlan1
network 10.255.255.0 0.0.0.255
network 192.168.50.0
no auto-summary
eigrp stub connected summary
Crypto Map and Tunnel Interface on HUB Router - 192.168.10.1
interface Tunnel3
bandwidth 8000
ip address 10.255.255.13 255.255.255.252
ip mtu 1420
qos pre-classify
crypto map hqmap
interface Tunnel0
bandwidth 8000
ip address 10.255.255.1 255.255.255.252
ip mtu 1420
tunnel destination 217.**.**.**
crypto map hqmap
crypto map hqmap 1 ipsec-isakmp
description ****** Link to 192.168.20.0/24******
set peer 217.**.**.**
set pfs group2
match address 101
crypto map hqmap 4 ipsec-isakmp
description ****** Link to 192.168.50.0/24 ******
set pfs group2
match address 104
access-list 100 deny   ip 192.168.10.0 0.0.0.255 192.168.0.0 0.0.255.255
access-list 100 permit ip 192.168.10.0 0.0.0.255 any
access-list 101 remark ****** Link to 192.168.20.0/24 ******
access-list 101 permit ip 192.168.10.0 0.0.0.255 192.168.20.0 0.0.0.255
access-list 104 remark ****** Link to 192.168.50.0/24 ******
access-list 104 permit ip 192.168.10.0 0.0.0.255 192.168.50.0 0.0.0.255
router eigrp 1
network 192.168.0.0 0.0.255.255
no auto-summary
Show IP Route on HUB Router
#sh ip route
D    192.168.30.0/24 [90/1602560] via 10.255.255.6, 01:45:27, Tunnel1
C       81.
**.**.**//32 is directly connected, Dialer1
C    192.168.10.0/24 is directly connected, Vlan1
D    192.168.40.0/24 [90/1602560] via 10.255.255.10, 1d23h, Tunnel2
D    192.168.20.0/24 [90/1602560] via 10.255.255.2, 06:11:01, Tunnel0
C       10.255.255.8 is directly connected, Tunnel2
C       10.255.255.12 is directly connected, Tunnel3
C       10.255.255.0 is directly connected, Tunnel0
C       10.255.255.4 is directly connected, Tunnel1
D    192.168.50.0/24 [90/1602560] via 10.255.255.14, 02:57:08, Tunnel3
Ping spoke from HUB Router
#ping 192.168.20.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 72/72/76 ms
Ping spoke from HUB Router using "source-interface" statement
Packet sent with a source address of 192.168.10.1
30 Replies 30
It looks like your original problem is with your crypto ACL. ...
Rated this post. Thank you for taking the time for explaining things.
The forum needs posts like your and not the too frequent noise by removed wannabes.
Hi p.bevilacqua,
I don't know what did I do to make you say so, but I got your point here. I will try to explain more if it is needed.
Lei Tian
Wow that was easier than i expected, Phase 3 DMVPN up and running! Just added the following commands to the hub config and all is well, thank you for your help Lei.
ip nhrp shortcut
ip nhrp redirect
Spoke Router:
#sh ip nhrp summary
IP NHRP cache 4 entries, 1312 bytes
    1 static  3 dynamic  0 incomplete
sh ip route
D    192.168.30.0/24 [90/3074560] via 10.255.255.3, 00:06:30, Tunnel0
C       81.**.**.0/24 is directly connected, Dialer1
D    192.168.10.0/24 [90/2818560] via 10.255.255.1, 00:06:30, Tunnel0
D    192.168.40.0/24 [90/3074560] via 10.255.255.4, 00:06:30, Tunnel0
D    192.168.20.0/24 [90/3074560] via 10.255.255.2, 00:06:30, Tunnel0
     10.0.0.0/24 is subnetted, 1 subnets
Hub Router
#sh ip nhrp summary
    0 static  4 dynamic  0 incomplete
#sh ip route
D    192.168.30.0/24 [90/2818560] via 10.255.255.3, 00:07:42, Tunnel0
D    192.168.40.0/24 [90/2818560] via 10.255.255.4, 00:07:43, Tunnel0
D    192.168.20.0/24 [90/2818560] via 10.255.255.2, 00:07:43, Tunnel0
D    192.168.50.0/24 [90/2818560] via 10.255.255.5, 00:07:41, Tunnel0
Hi Mark,
I am glad that I can help you. One thing I noticed you still have "no ip next-hop-self eigrp 1" under your hub tunnel interface. The show ip route output on spokes points to remote site spoke router as next-hop. You might want to remove "no ip next-hop-self eigrp 1" on hub router.
With " no ip next-hop-self eigrp1" on hub router, spoke's NHRP resolution request will be processed like phase 2. Which is spoke 1 send nhrp request for spoke 2; hub find the NHRP mapping in its database and reply spoke 1; spoke 1 initial the tunnel with spoke 2. Before the spoke to spoke tunnel established, all traffic will through hub.
For phase 3 to work properly you need to remove "no ip next-hop-self eigrp1" on hub router. So the hub router instead of doing NHRP map lookup and reply NHRP request, it just redirect the NHRP request to the remote spoke.
HTH,
Lei Tian
Thank you Lei, this is the tunnel configuration i have for the HUB at present, i have tested spoke to spoke connectivtiy with ICMP. With first set of requests go via the HUB, the second go direct to the other spoke.
If i remove the statement " no ip next-hop-self eigrp 1" ie change it to " ip next-hop-self eigrp 1" the configuration becomes Phase2 and all spokes talk to one another via the HUB. Although when i removed the statement i dont think i allowed time for the tunnel interface to be reset so ill try that later.
Also is it advisable to add the "EIGRP STUB" command to spoke routers?
Your advice is much appreciated.
Initial Ping
#ping 192.168.20.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 100/121/132 ms
Second Ping
#ping 192.168.20.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 68/70/72 ms
These sites are DSL so the response time is somewhat higher.
HUB Tunnel Config
interface Tunnel0
description ****** DMVPN GRE Tunnel ******
bandwidth 1000
ip address 10.255.255.1 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp authentication RUcW52LQ
ip nhrp map multicast dynamic
ip nhrp network-id 100000
ip nhrp holdtime 360
ip nhrp redirect
ip tcp adjust-mss 1360
no ip split-horizon eigrp 1
delay 1000
qos pre-classify
tunnel mode gre multipoint
tunnel key 100000
tunnel protection ipsec profile DMVPN
Spoke Tunnel Config
interface Tunnel0
bandwidth 1000
ip address 10.255.255.5 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp map multicast **.**.**.**
ip nhrp map 10.255.255.1
ip nhrp nhs 10.255.255.1
ip nhrp shortcut
ip nhrp redirect
delay 1000
qos pre-classify
tunnel key 100000
Hi Mark,
As I mentioned you still have "no ip next-hop-self eigrp 1" on your hub; you need remove that statement for phase 3 to work properly.
Actually, it is the other way around. with "no ip next-hop-self eigrp 1" it will work as phase 2, and phase 3 do not need that statement on hub. After established  the dynamic tunnel, traffic from spoke to spoke will be sent via the ipsec tunnel and will not process by hub router. Be aware remove "no ip next-hop-self eigrp 1" on hub router will reset all eigrp neighbors.
These are little difference between phase 3 and phase 2. When you send traffic from spoke 1 to spoke 2,in phase 2 ipsec tunnel is initialed by spoke 1; in phase 3 ipsec tunnel is initialed by spoke 2. From user point of view, you might not even notice the difference. What matter is in phase 2, before spoke to spoke tunnel established, traffic will be process switched by hub router; in phase 3 all traffic are cef switched. That gives phase 3 a big plus when you have lot spokes. Phase 3 also build up spoke to spoke tunnel quicker than phase 2. You can verify that by doing ping from spoke 1 to spoke 2 with phase 2 and phase 3, and compare the number of pkt been encrypted from "show crypto ipsec sa".
In term of best practice, it doesn’t hurt to put spoke as eigrp stub network, but it wont help anything unless you have dual hub. For dual hub situation, you want put spoke as stub network so it won’t become transit site.
This is a good document for migrating DMVPN phase 2 to phase 3; you can find some best practices in the doc as well.
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6586/ps6660/ps6808/prod_white_paper0900aecd8055c34e_ps6658_Products_White_Paper.html
HTH,
Lei Tian
Excellent information Lei, i think its all working as expected now. All strange thing is that when i ping spoke to spoke the dynamic tunnel is created but the routing table still points to the hub at the next hop.
HUB Config
interface Tunnel0
bandwidth 1000
no ip redirects
ip mtu 1400
ip nhrp redirect
delay 1000
qos pre-classify
tunnel key 100000
router eigrp 1
network 10.255.255.1 0.0.0.0
no auto-summary
#sh ip route
D    192.168.30.0/24 [90/2818560] via 10.255.255.3, 00:09:48, Tunnel0
C       81.
D    192.168.40.0/24 [90/2818560] via 10.255.255.4, 00:09:49, Tunnel0
D    192.168.20.0/24 [90/2818560] via 10.255.255.2, 00:09:47, Tunnel0
D    192.168.50.0/24 [90/2818560] via 10.255.255.5, 00:10:09, Tunnel0
Spoke Config
interface Tunnel0
bandwidth 1000
no ip redirects
ip mtu 1400
ip nhrp shortcut
ip nhrp redirect
delay 1000
qos pre-classify
tunnel key 100000
router eigrp 1
network 10.255.255.5 0.0.0.0
no auto-summary
Success rate is 100 percent (5/5), round-trip min/avg/max = 124/125/128 ms
Success rate is 100 percent (5/5), round-trip min/avg/max = 96/98/100 ms
#traceroute 192.168.20.1 source vlan 1
  1 10.255.255.2 68 msec *  68 msec
#sh ip route
D    192.168.30.0/24 [90/3074560] via 10.255.255.1, 00:12:31, Tunnel0
D    192.168.10.0/24 [90/2818560] via 10.255.255.1, 00:12:52, Tunnel0
D    192.168.40.0/24 [90/3074560] via 10.255.255.1, 00:12:31, Tunnel0
D    192.168.20.0/24 [90/3074560] via 10.255.255.1, 00:12:29, Tunnel0
Hi Mark,
What you have seen is the correct behavior. In Phase 3, spoke will always point to hub as the next-hop in the routing table; what changed is the nhrp map. If you goto the spoke router and show ip nhrp brief, you will notice there will be one entry for remote spoke tunnel's (10.255.255.2 in your case), and another entry for remote spoke's LAN subnet (192.168.20.0 in your case). The later entry will be used when traffic send to 192.168.20.0 subnet.
And because of this feature, phase 3 allows you on hub router only advertise summary route to spokes.
HTH,
Lei Tian
Yep all is fine there, really appreciate your time Lei, it's certainly a more efficient way of working..right thats one down, next project is is B2B DMVPN!
Glad to help; come back when you have questions.
Much appreciated, one quick query can you apply an inbound ACL on a tunnel interface to deny certain subnets/ports/protocols etc from specific spokes.
For example a third party IT services provider requires sporadic access to the customers DMVPN network in order to manage internal Client/Server assets.
The IT Services provider would like to establish temporary IPSEC tunnels with the customer for the purpose of securing management traffic between the customer internal LAN's and the IT Service provider, the IT Service provider wants to join to the customers DMVPN network as an additional spoke site but does not want the customer to be able access their own network.
Hi Mark,
Yes, you can apply ACL on tunnel interface to deny certain type of traffic on either direction.
After read your requirement, I think reflexive acl might be a good fit here. Say provider site is spoke 1 and the customer site is spoke 2; any traffic originate by spoke 1 and return traffic can pass, but traffic originate by spoke 2 would be blocked. Here is  the configuration guide if you are interested with reflexive acl.
http://www.cisco.com/en/US/docs/ios/sec_data_plane/configuration/guide/sec_cfg_ip_filter_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1000897
HTH,
Lei Tian
Excellent idea thank you.
In no way I was referring to your contributions, rather to people in other threads that think they can voice their uninformed opinion just because they have played a couple hours with 2500s.
Brilliant explanation, thank you
