03-05-2009 01:34 PM - edited 03-04-2019 03:49 AM
When I boot my cisco 2620xm it show wierd characters and wont let me do anything. First this was cuased by a power failure when hte router was upgrading. Second I have used the jumpers to reset the console speed with no luck. finally i have removed all modules to see if they were the problem but its no use. How do I fix this router? Its used in a classrooms lab setup.
03-06-2009 12:05 AM
Hello Harry,
a C2620xm should have a software based config-register.
try to connect to the console using different speeds until you see readable output
Hope to help
Giuseppe
03-06-2009 04:05 PM
Jumpers???
You will have to patiently try out every speed there is on the console terminal. No choice.
