10-22-2007 09:52 PM - edited 03-03-2019 07:17 PM
Hi, is it possible to send changes made to routers to a syslog server, we make changes via telnet and console cable and need to keep track of everything.
Solved! Go to Solution.
10-23-2007 12:00 AM
You can do this via AAA.
But there was recent feature introduced in the IOS which can be helpful and does not need a AAA server
have a look at this link
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a0080454f73.html
Narayan
10-22-2007 10:18 PM
HI,
You can enable SNMP Trap messages for VTY and Console logging.
If the changes is going to be made via only certain sources means, an ACL can be defined with "LOG" enabled.
Best Regards,
Guru Prasad R
10-22-2007 11:48 PM
Can I have an example of how I configure this, it would be very helpful.
10-23-2007 12:00 AM
Narayan
10-23-2007 12:15 AM
HI Narayan,
Well and Wish to hear same from you.
Great Link posted by you and it was really helpful in huge production environments operating in various shift timings.
I have recommended to another Project to implement this Techniq.
Thanks for your Link and Great Support. Have rated your POST.
Best Regards,
Guru Prasad R
10-23-2007 02:10 AM
Thanks for the rating Guru
Narayan
10-23-2007 12:54 AM
*edit* answered to an older post - didn't see the reply from Narayan.
There are two possible questions in what you are saying.
1. You need to know IF device was configured, and by WHO
2. You need to know WHAT was configured and by WHO.
The first one you can accomplish by using syslog server. The message will always appear in the log is the following:
%SYS-5-CONFIG_I: Configured from console by console
So all you have to do is configure:
logging x.x.x.x
logging trap 5
For the second one, you would need to configure AAA (Authentication, Authorization and Accounting). Particularly accounting of all entered bytes. This is not possible with Syslog AFAIK. Here is a link of TACACS overview. http://cisco.com/en/US/partner/docs/ios/11_3/security/configuration/guide/sctplus.html#wp20706
You will need a TACACS or RADIUS server for this.
Hope this helps
10-23-2007 08:08 AM
10-23-2007 08:14 AM
Your URL is asking for CCO login to which i dont have an access. Can anyone provide me with CCO login?
10-23-2007 08:16 AM
You can create your own for free! Go to http://tools.cisco.com/RPF/register/register.do and fill out the form.
