01-27-2009 04:10 AM - edited 03-04-2019 12:59 AM
We are unable to run the Card Type command on Cisco 2811 Router the IOS Image deployed is c2800nm-adventerprisek9-mz.124-22.T.bin
Kindly suggest.
01-27-2009 04:31 AM
Navinder
Perhaps it would help us figure out the problem if you would tell the exact command you try to use and the exact response that you receive. It might also be helpful if you would post the output of show diag from the router.
Rick
01-27-2009 04:57 AM
01-27-2009 09:44 AM
you need to contact the TAC on this issue, as it is not normal that the module is not recognized. In the manwhile you can try another image.
01-28-2009 12:17 AM
Hi Navinder,
Please post the exact command and the error that you are getting.
Would it be possible to attach 'show run' as well? You may mask any IP addresses or passwords from the config.
~Vaibhav
