card type
Can anyone explain for which controller cards we need to have this command...'card type E1/T1 slot#'
how to identify..
Gaurav
Re: card type
AFAIK its reqd for PA-MC-8TE1+ coz it can be used to connect both E1 or T1 lines..
regds
Re: card type
Almost all newly released cards are having T1/E1 functionality built into the hardware. Most NMs used for voice (NM-HDV2) as well as the VWIC2's need this command to configure it as T1 or E1 port. Unless you configure this command, the ports wont show up in the sh version or running config.
Re: card type
hi shanky
shanky for NM-2CE1T1 cards we have to configure
card type command,but for VWIC-2MFT cards this command is not required.it will automatically detect controller's.last week i configured 6 VWIC cards
after inserting the cards if you create the channel group it will generate the serial interface.
Regds
Binoy.
Re: card type
Binoy,
Are you talking about vwic2-2mft-t1/e1 or vwic-2mft-t1 ?
Note the difference between the two vwics, one is gen2 and other is gen1. I know the gen1's does not need the card type command, as they are either t1 only or e1 only and not both.
The vwic2-2mft-t1/e1 can be configured as an e1 or t1. Even though I have not configured one of these yet, I believe you still have to specify what kind of port it is using card type command.
Hope that clears the confusion regarding my statement in the previous post.
Re: card type
Shanky,
i'm talking abt VWIC-2MFT-E1.Yes you are correct shanky, like when we configure NM-2CE1T1-PRI we need to specify card type E1 or T1.so it should be same for
VWIC2-2MFT-T1/E1.
IF you have documents related to this please give me the link.
Regds
Binoy.
497
