CASR 1002 stop reponsding when generating an RSA key.
When I issue the commande crypto key generate rsa the router stop responding and don't generate any key.
It is the same behaviour when i issue the ip http secure-server
Do you have an idea
DMHUB1#sh version
Cisco IOS Software, IOS-XE Software (PPC_LINUX_IOSD-ADVENTERPRISEK9-M), Version 15.3(1)S1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Fri 08-Feb-13 10:04 by mcpre
IOS XE Version: 03.08.01.S
Cisco IOS-XE software, Copyright (c) 2005-2013 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
HUB1 uptime is 5 days, 20 hours, 50 minutes
Uptime for this control processor is 5 days, 20 hours, 53 minutes
System returned to ROM by reload
System image file is "bootflash:asr1000rp1-packages-adventerprisek9.03.08.01.S.153-1."
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco ASR1002 (2RU) processor with 657321K/6147K bytes of memory.
Processor board ID
4 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
7757823K bytes of eUSB flash at bootflash:.
20
