CATOS Hybrid to Native Conversion
GREGORY JACKSON
IS there a utility that will allow you to take you catOS configuiration (NOT Firmware or software) and change it to and IOS configuration?
srimural
Hi Rabalam,
Yes there is a utility to convert CatOS configs to IOS configs. After doing the same , please ensure that all requirement is met and all the commands are converted.
Please find the below link
http://cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a0080816fbc.shtml
https://upload.cisco.com/cgi-bin/swc/fileexg/main.cgi?CONTYPES=ccu-forum
Please use ur CCO login to download the software.
All the step by step procedures are mentioned.
Thanks and Regards,
Srinath.M
Cable&Wireless.
Please do not forget to rate this
