CBWFQ-Frame-relay (Trying to implement COSoFR on MPLS)
Hi Folks,
I am try to implement service-policy and getting the below error message.
I/f Serial0/1/1.100 DLCI 100 class interactive_voice_or_video requested bandwidt
h 512 (kbps), available only 28 (kbps)
Router#sh run int serial 0/1/1
Building configuration...
Current configuration : 158 bytes
interface Serial0/1/1
bandwidth 2048
no ip address
encapsulation frame-relay
no fair-queue
frame-relay traffic-shaping
frame-relay lmi-type ansi
end
Router#sh run int serial 0/1/1.100
Current configuration : 153 bytes
interface Serial0/1/1.100 point-to-point
bandwidth 2048
ip address 172.16.2.2 255.255.255.252
ip nat inside
frame-relay interface-dlci 100
end
class-map match-any interactive_voice_or_video
match access-group name interactive_voice_or_video
class-map match-any best_effort
match access-group name best_effort
policy-map parent
police 512000 64000 96000 conform-action transmit exceed-action drop
priority 512
class best_effort
shape average 1600000
policy-map set_precedence
set ip precedence 5
class best_effort
set ip precedence 0
map-class frame-relay FRMAP-MPLS
service-policy output parent
Re: CBWFQ-Frame-relay (Trying to implement COSoFR on MPLS)
Hey,
although you are not using the adaptive becn\fecn operation, you should set the mincir. try to set it to the same value you are policing to.
How to change the mincir value.Please share the command reference & usage guidelines.
i am still facing issues and getting below error message.
h 512 (kbps), available only 1 (kbps)
Below changes:-
frame-relay cir in 2048
frame-relay adaptive-shaping interface-congestion 40
frame-relay cir out 2048
frame-relay mincir 1024
frame-relay holdq 1024
hey,
try putting "frame-relay mincir 524288" under the map-class.
The reason for this is that somehow the mincir is assumed to be the available bandwidth in policing, although it relates to shaping.
159
