Community Member
CBWFQ over FR
I'd like to configure CBWFQ over FR as below, one subinterface is for TCP user and another is for voice user.
Does subinterfaces inherently support CBWFQ?
class-map match-all TCP
match access-group 103
class-map match-all VOICE
match access-group 102
policy-map CBWFQ
class VOICE
bandwidth percent 45
class TCP
bandwidth percent 30
class class-default
fair-queue
interface Serial0/0
no ip address
encapsulation frame-relay
service-policy out CBWFQ
interface Serial0/0.1 point-to-point
ip address 192.168.10.1 255.255.255.0
frame-relay interface-dlci 400
interface Serial0/0.2 point-to-point
ip address 192.168.11.1 255.255.255.0
frame-relay interface-dlci 500
VIP Purple
Re: CBWFQ over FR
no, the policy is not inherited on the subinterfaces. For your configuration to work, you need to apply the following:
policy-map CBWFQ
class VOICE
class TCP
class class-default
fair-queue
interface Serial0/0
no ip address
--> frame-relay traffic-shaping
--> class DLCI_400
--> class DLCI_500
--> map-class frame-relay DLCI_400
service-policy output CBWFQ
--> map-class frame-relay DLCI_500
Watch out though, once you have enabled Frame Relay Traffic Shaping on your main interface, all the DLCI configured on the subinterfaces will default to 56000kbps. If, and that is likely, that is not what your DLCIs actually have available as bandwidth, configure the cir and bc/be values in the frame relay classes as well...
Let me know if you have problems with this.
GP
Silver
Re: CBWFQ over FR
http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a0080110bc6.html
Check this link out. It replaces the legacy FRTS with MQC based commands. So ur restriction of 56K per PVC is removed in this.
Regds
Community Member
Re: CBWFQ over FR
Hi GP/THT
thanks for answering, I knew CBWFQ for every logical interface is shape function need first,,,
what i am asking is somehow i should apply CBWFQ on main interface with ip addess based classes, and some cisco document saying that it works like single pipe, because subinterface is just logical interface.
configuration is more like this
policy-map CBWFQ
class VOICE
class TCP
class class-default
fair-queue
interface Serial0/0
no ip address
access-list 102 permit ip any 192.168.11.1 0.0.0.255
access-list 103 permit ip any 192.168.10.1 0.0.0.255
Had anybody been through before?
Silver
Re: CBWFQ over FR
Iam not sure this will work. But i was going through some document on using PVC bundles and mapping to IP QoS etc. It didnt make much of sense to me. Hope it helps you.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a0080153e16.html
Regds
p.s:- Let me know if it is path-breaking. Iam exploring this too.
126
