Webcast-Catalyst9k
cbwfq & route-cache cef
Hi Guys,
If we need to apply cbwfq on the router do we have to enable cef first.
I have cbwfq and cef enabled globally but there is a command on the wan interface of the router "no ip route-cache" will it have any impact on the qos enabled on the router.
Tks
1 ACCEPTED SOLUTION
Hall of Fame Super Blue
Re: cbwfq & route-cache cef
Attached is a doc that lists all the Class based QOS features that require CEF, so if you intend to use any of the features in the list then yes you need to enable CEF -
http://www.cisco.com/en/US/tech/tk39/tk824/technologies_tech_note09186a0080094978.shtml#topic2
Jon
Jon
Super Bronze
"If we need to apply cbwfq on the router do we have to enable cef first."
Answered by Jon's reference.
"I have cbwfq and cef enabled globally but there is a command on the wan interface of the router "no ip route-cache" will it have any impact on the qos enabled on the router. "
I believe with CEF, "ip route-cache" serves no effective purpose and whether it's enabled or not shouldn't impact QoS functioning. However, unsure whether activation or deactivation of it has any impact against router resources (i.e. CPU, memory).
142
