CBWQ and interface bandwidth
I'm trying to use CBWQ to share a career link beetween two agencies.
I'm using classe based weight queue to do that.
I have one interface by agency and one wan interface (fastethernet connected to a 2mbit/s link where the policy is applied).
The problem is not in the bandwidth sharing (I have two class with a match input interface and a policy that provide a bandwith percent for each class) but about the wan interface. How can i tell the qos mecanism that my total bandwidth is not 100mbit/s (fastethernet) but 2mbit/s ?
I've tried with the keyword bandwith in the interface config mode but it does not limit the trafic...
Thank you for your help
1 ACCEPTED SOLUTION
Re: CBWQ and interface bandwidth
np - glad to help.
You need to look at Traffic Shaping, see the below link:-
http://www.cisco.com/en/US/docs/internetworking/technology/handbook/QoS.html
I've already read that.
My config :
class one
match input interface f0/1
class two
match input interface f0/0/0
policy-map bandwith-share
class one bandwith 50 percent
class two bandwith 50 percent
int f0/0
service policy output bandwdwith-share
How can I configure my router to tell the qos that there is only 2mbit/s to share and not 100mbit/s ?
That is not traffic shaping, you are just allocating 50% of the available interface bandwith, you need to shape the traffic, ie define how much bandwidth can be sent over a time period, or you can police the traffic witch defines how much bandwidth can be used in bits.
read the below link and use the config examples to build your requirements:-
http://www.cisco.com/en/US/tech/tk543/tk545/technologies_tech_note09186a00800a3a25.shtml#trafficshaping
HTH>
I would configure something like:-
ip access-list standard customer1
permit 172.16.1.0 0.0.0.255
ip access-list standard customer2
permit 172.16.31.0 0.0.0.255
class-map match-all cust-1
match access-group name customer1
class-map match-all cust-2
match access-group name customer2
policy-map customers
class cust-1
bandwidth percent 50
class cust-2
policy-map shape-customers
class class-default
shape average 4194304
service-policy customers
HTH>
Ok thank you very much !
np - glad to help.
Ok so the above config will do the job ?
class one
class two
policy-map parent
class class-default
police 2048000 103000 103000 conform-action transmit exceed-action drop
service-policy bandwidth-share
int f0/0
Thank you very much !
Super Bronze
No, you want:
(edit2 NB: syntax might be incorrect)
class one
class two
class one
!syntax might be bandwith percent remaining 50
bandwith remaining percent 50
class two
policy-map parent
class class-default
shape avg 2048000
int f0/0
service policy output parent
[edit]
BTW, on many platforms/IOSs, the shaper alone will do (W)FQ. I.e. you might find traffic behavior is better without the child policy.
[edit2]
i.e.
either
policy-map apolicy
class class-default
shape avg 2048000
int f0/0
service policy output apolicy
or
int fa0/0
traffic-shape avg 2048000
433
