cdp neighbors over serial
Just curious, shouldn't cdp work also for neighbor devices connected via serial links like frame relay?  If it shouldn't work, is it because cdp is primarily a layer 2 function and would not work on serial links which basically uses its own layer 2 protocols.
Thanks in advance.
Hall of Fame Super Silver
CDP certainly works over most serial interface types. Here is a quote from a Cisco document
CDP is enabled by default on all supported  interfaces (except for Frame Relay multipoint subinterfaces) to send and  receive CDP information. However, some interfaces, such as ATM  interfaces, do not support CDP.
So perhaps you are encountering the Frame Relay multipoint subinterface restriction?
Here is the URL if you want more detail
http://www.cisco.com/en/US/docs/ios/12_1/configfun/configuration/guide/fcd301c.html
Rick
Hi Richard,
Appreciate the reply.
Was checking other resources and apparently i have to enable cdp on the MFR subinterface.
Thanks again.
840
