Webcast-Catalyst9k
cef load-sharing on hwic-4esw
I am currently running the
"ip cef load-sharing algorithm include-ports source destination"
command on a 2821 router.
The load sharing is done to five 800 series ADSL routers which are all connected via G0/1.
I need to move this connection to a port on an Hwic-4esw card.
I wanted to know if the hwic is capable of handling the load-sharing the same way that the integrated interface does. I'm a bit leary because the hwic interface is very limiting in many ways.
I know I have to create and assign a vlan to the interface before it will route.
Dan.
1 REPLY
Hall of Fame Super Gold
Re: cef load-sharing on hwic-4esw
It should work no problem.
136
