Webcast-Catalyst9k
Cellular Interface IP Address discovery
Does anybody know a command that will let me discover what IP address has been assigned to my Cellular interface? It is on Sprint's network and IOTA was used to activate the card and the "IP address negotiated" command was entered under the Cellular Interface in the config.
Re: Cellular Interface IP Address discovery
ipconfig /all from a DOS prompt in Windows.
If you are on a router with a 3G interface with a negotiated address you can just issue a show ip interface to see the assigned address when there is an active connection.
193
