Change of NPE300, now OutputDrops and not Full Bandwidth
Hi there,
we must change the NPE300 of our 7024VXR,cause of hardware failure. Since this, we have Output Drops on the POS Modul low Bandwidth, means on our POS Line (155MBit/s) we could only transfer aprox. 130MBit/s.
Hardwaredetails:
7204VXT with NPE300 (256MB RAM)
Slot 3:POS (155MBit/s)
Slot 4:GigabitModul(1 GBIC used 1GBit/s)
I/O FE Port: 100Mbits used for 2nd Uplink
sh int pos3/0
POS3/0 is up, line protocol is up
Hardware is Packet over Sonet
Description: Transit to xxxxxx
Internet address is x.x.x.x/30
MTU 4470 bytes, BW 155000 Kbit, DLY 100 usec,
reliability 255/255, txload 206/255, rxload 23/255
Encapsulation PPP, crc 16, loopback not set
Keepalive set (10 sec)
Scramble disabled
LCP Open
Open: IPCP
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 00:00:54
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 6816
Queueing strategy: fifo
Output queue: 0/40 (size/max)
1 minute input rate 14243000 bits/sec, 12023 packets/sec
1 minute output rate 125799000 bits/sec, 15312 packets/sec
645900 packets input, 98016689 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 parity
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
819582 packets output, 845517366 bytes, 0 underruns
0 output errors, 0 applique, 0 interface resets
0 carrier transitions
Can anyone give us some hins ?
The Link Partner says, on his side there are no drops, there is no limit on the interface etc, it must our hardware, but the only thing we changed is the NPE300 with a NPE300 .. so this should not be the point, i think.
Thank you in advance Timo
BTW: If you need more info, please ask :)
Re: Change of NPE300, now OutputDrops and not Full Bandwidth
5 minutes later, output of : sh int pos3/0
reliability 255/255, txload 206/255, rxload 19/255
Scramble disabled
LCP Open
Open: IPCP
Last clearing of "show interface" counters 00:06:21
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 35361
1 minute input rate 12144000 bits/sec, 11408 packets/sec
1 minute output rate 125423000 bits/sec, 14938 packets/sec
4409347 packets input, 604586886 bytes, 0 no buffer
0 parity
5718012 packets output, 1690009256 bytes, 0 underruns
I have the same issue with a POS interface. I am interested in what becomes of this issue. I have been told to use WRED. What I don't understand is we have plenty of bandwidth. We are only using about 30 to 40 MB out of the 155MB.
Curious?!
Hall of Fame Super Gold
Old thread revived. For historical purposes, i can say the original poster's problem was probably normal behavior caused by bursty traffic.
Now, 30-40 mbps out of an oc-3, is not normal. Would you please send show config and show interface for all interfaces involved in this traffic flow, as well mentioning the exact platform and IOS used.
here is the info attached
Hi, on output on pos1/0 you have dropped less than 0.2% of total packets sent. This small number can be due to burstiness and is normal
You should check the if the value increase over time and when. Since you have the default 5-minutes average, you will never be able to tell bursty moments just looking at show interface.
Also the other interface you sent output is shutdown so I can't tell from/to the pos1/0 traffic goes and if that other interface is normal.
keep in mind they increased the output queue to 3840 ... which causing a ton of retransmissions. This is why the drops have decreased but still have some. If I remove the output queue the drops are ridiculous.
163
