08-19-2008 06:53 PM - edited 03-03-2019 11:12 PM
Hi All.
Is it possible to change the Admin Distance on eBGP routes (using 'Distance' cmd, I guess), but only from a specific AS?
IOS 12.2SX
I guess what I'm looking for is the Distance cmd to reference a route-map instead of an ACL.
Cheers
David
08-20-2008 05:52 AM
David,
What is the need for changing the AD for Ebgp for some specific routes?
If you are trying to do this to modify routing preference, then there are lot of other attributes which you can use with BGP
Narayan
09-07-2008 05:35 PM
Hi Narayan,
I have a preference for certain EIGRP routes to be chosen over their BGP equivalents but it'd be simpler if I could reference the origination AS instead of a few hundred routes.
09-07-2008 06:16 PM
In that case you can do it under EIGRP but only for internal EIGRP routes, you can't do it under the BGP routing process.
See a sample in my lab:
I want to make 10.1.2.2 an EIGRP route:
Rack1R1#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
192.168.12.0/30 is subnetted, 1 subnets
C 192.168.12.0 is directly connected, Serial1/0
20.0.0.0/32 is subnetted, 1 subnets
B 20.1.2.2 [20/0] via 192.168.12.2, 00:03:41
10.0.0.0/32 is subnetted, 1 subnets
B 10.1.2.2 [20/0] via 192.168.12.2, 00:03:41
150.1.0.0/32 is subnetted, 1 subnets
B 150.1.2.2 [20/0] via 192.168.12.2, 00:03:41
____________________________
access-list 1 permit 10.1.2.2
router eigrp 1
network 192.168.12.1 0.0.0.0
distance 19 192.168.12.2 0.0.0.0 1
no auto-summary
_______________________________________
Rack1R1#sh ip route
B 20.1.2.2 [20/0] via 192.168.12.2, 00:03:51
D 10.1.2.2 [19/2297856] via 192.168.12.2, 00:00:07, Serial1/0
B 150.1.2.2 [20/0] via 192.168.12.2, 00:03:51
HTH,
____
Edison.
Please rate helpful posts
09-07-2008 06:47 PM
That does help, thank you, but unfortunately I do need it also for EIGRP external routes.
09-07-2008 08:01 PM
Hi David,
Too bad, this can only be done with internal EIGRP routes.
You can't use the distance command within a route-map for BGP routes.
__
Edison.
09-08-2008 04:17 AM
Hi.
you can use the network backdoor command, under bgp, for this routes.
It's for this problem.
09-10-2008 08:01 AM
Perhaps you could use the network backdoor command to influence the route
