Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
changing static nat on asa
Hi i need to change static association for a public ip to internal ip
right now i have following statment.
static (dmz,outside) 66.xx.xx.xx 192.168.50.91 netmask 255.255.255.255
it needs to be changed to
192.168.51.14 netmask 255.255.255.255
what should I need to do ?
do i need to add no statment to previous statement and execute new ?
1 REPLY
Hall of Fame Super Blue
Re: changing static nat on asa
yes you should do
no static (dmz,outside) 66.xx.xx.xx 192.168.50.91 netmask 255.255.255.255
then
You will then need to clear the xlate. Do not just enter "clear xlate" as it will remove all the xlates which will break all existing connections through the ASA.
Do
clear xlate global 66.xx.xx.xx
Jon
112
