Webcast-Catalyst9k
Changing the default gateway
I need to change the default gateway on a router that already has it set. How can you change the default gateway. Any help will be appreciated.
Bronze
Re: Changing the default gateway
hi,
Use the command in global configuration
to remove ur existing defualt gateway
When ip routing is enabled on the Cisco router
router(config)#no ip default-network x.x.x.x
and add this command
router(config)#ip default-network x.x.x.x
and
when ip routing is disabled on the Cisco router.
use this commands
router(config)#no ip default-gateway x.x.x.x
to remove existing default router.
add using
router(config)#ip default-gateway x.x.x.x
Raj
Hall of Fame Super Bronze
The default gateway is usually represented with the command
ip route 0.0.0.0 0.0.0.0 [default gateway ip]
However, the default gateway can also be injected from remote routers by using dynamic routing protocols.
If you post the output from typing
#show ip route 0.0.0.0
we can help you better.
326
