07-22-2006 03:53 AM - edited 03-03-2019 01:25 PM
I want to configure Channlize E1 on my 2600 series router on my 2600 router i have 2 wic card.
The IOS version of my router Version 12.2(7b)
07-22-2006 04:42 AM
You have mentioned WIC cards.No word of E1 card?Pls give information about that also.
Pls tell us:
(1)That will be for data or for voice?
(2)Is it framed or unframed.
(3)CRC is on or off.
Anyway The standard 2 Mbps config for data is:
On controller e1 give following commands:
"channel-group 0 timeslots 1-31 speed 64
clock rate line
line-code HDB3
framing no-CRC4"
Then a serial interface will pop-up, you have to configure it similar to any serial interface
"int s0:15
ip add
encap
Pls look at following link.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/12cgcr/dial_c/dcchant.htm#4736
Pls revert back if u have more questions.
Pls rate all posts.
JD
07-22-2006 05:51 AM
Thanks for teh reply !!!!
i am useing it for voice and i am transporting voice and the backhand i am using (PSAX2300 Lucent atm )
and for voice should change my speed ??
and other thing more
channel-group 0 ??
channel-group 1 ??
any differnce between them ???
07-22-2006 06:26 AM
(1)You will need to configure "pri-group" instead of "channel-group".
Do not forget to define "isdn switch-type" before giving "pri-group" command.
(2)The pri-group/channel-group 0 or 1 or anything defines the timeslots.
Say, There are 30 channels in an E1, if you want to configure each for seperate speeds (for data), then
channel-group 0 timeslots 1 ===== speed=64K
channel-group 1 timeslots 2-3 ===== speed=128K
....and so on.
As I have mentioned earlier each group creates a serial interface, hence you can seperately define config. for each.
......I believe I have made myself clear?
Pls tell us what exactly you want to do with it, and if possible a network diagram
Pls view the following links.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/12cgcr/dial_c/dcchant.htm#5070
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/12cgcr/dial_c/index.htm
Hope it helps.
JD
07-22-2006 07:01 AM
Is your problem solved?
JD
07-24-2006 02:03 AM
Hi,,
Thanks for ur all relpies..
yes i have configur my router as per ur advise and ur forwareded links.
Thanks ......
07-24-2006 03:00 AM
I was just intrested in knowing how this setup you are doing?
(1)
(2)
(3)
Pls tell me which setup it is.If its VoDSL, can you please do me favour of a posting a network diagram of it?
JD
07-24-2006 03:55 AM
Mr. JD
We are LDI operator and we are usig Lucent as backbone related to my Question we are just going to intgrating our differenet networks togather.and for this purpose we are performing some expierment for this.
for this we are intaitialy working on this Scanario
basic one
Lucent--- cisco -------- Cisco ---- Lucent.
07-24-2006 04:16 AM
JD
