channelized 2 - T1 frame relay circuits in 2811 routers
I'm trying to connect one of my company site back to its head quarter. The site has 1 2811 router, and 2 of T1 frame relay circuits connected back to head quarter. Each T1 circuit is connect to WIC-1DSU-T1-V2 card on 2811 router.
Can I channelized these 2 T1 frame relay circuits to become 1 logical connection? What is the configuration for it? Or does it require a special card?
Thank so lot. I really need help on this.
Tung.
Purple
Re: channelized 2 - T1 frame relay circuits in 2811 routers
Hi Tung,
You can't combine the two T1s at a physical layer but you can use Multilink PPP so that they appear as a single logival circuit. This is a software feature and does not require any additional hardware.
Here's an example of how you could do this:
Router 1
interface Multilink1
ip address 10.1.1.1 255.255.255.0
no cdp enable
ppp multilink
ppp multilink group 1
interface Serial0
no ip address
encapsulation ppp
ppp multilink
interface Serial1
no ip address
encapsulation ppp
ppp multilink
Router 2
ip address 10.1.1.2 255.255.255.0
no cdp enable
ppp multilink
interface Serial0
no ip address
encapsulation ppp
ppp multilink
interface Serial1
no ip address
encapsulation ppp
ppp multilink
Hope that helps - pls do remember to rate posts that help.
Paresh
Hi Paresh,
But the circuits I have is frame-relay T1 with DLCI # for every PVC. Can I still implement Multilink PPP over frame-relay circuit?
Thank so lot.
Tung.
Purple
Tung,
You can run MLPPP over FR links. Check out this link:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cg/hqos_c/part30/ch05/qslfifr.htm
Pls do remember to rate posts.
Paresh
331
