Channelized DS3
rgenovesi
Is it possible to aggregate multiple T1 channels on a channelized DS3?
For example can I use mlppp to aggregate 3 T1s from Site A to a channelized DS3 at Site B?
Thanks!
pkhatri
Level 11
Level 11
I'm pretty sure that is possible since each of the channels on the channelised DS3 results in a separate serial interface. Therefore, you should be able to include those serials in a MLPPP group.
Hope that helps - pls rate the post if it does.
Paresh
According to the spec sheet of the PA-MC-T3 it is *not* supported...
http://www.cisco.com/en/US/products/hw/modules/ps2033/products_module_installation_guide_chapter09186a00801125e3.html
"Aggregation of multiple T1 lines is not supported." Maybe I am misreading this or they are referring to something else? I hope so...
-Rob
Rob,
I think what they mean by that is that you cannot create an interface that spans more than one T1. That would not be a reference to MLPPP, specifically..
Having said that, it's not something I've tried personally.
Paresh
