Webcast-Catalyst9k
Channelized T1 shared port adaptor
I want to use channelized T1 shared port adaptor. I have seen that for configuring the IP address we have to go to serial interface.
Can you please confirm that which serial interface is associated with the channelized T1 adaptor?
Is it a separate serial interface or inbuild in the channelized T1 shared port adaptor?
Mukesh Kumar
Network Engineer
Spooster IT Services
1 ACCEPTED SOLUTION
Hi,The configuration examples
The configuration examples that show you how to configure a channelized T1 interface indeed refer to Serial interfaces. These Serial interfaces are logical interfaces that will be created by your IOS as soon as you configured the T1 controller with the framing information. There are no additional serial interfaces to be installed into your router - the T1 controller should contain all necessary hardware.
You may find this page helpful as well:
http://www.cisco.com/c/en/us/td/docs/ios/interface/configuration/guide/ir_halfport_pri_net_mod.html
Best regards,
Peter
Best regards,
Peter
Thanks a lot Peter.  Regards
Thanks a lot Peter.
Mukesh Kumar
Network Engineer
18
