Webcast-Catalyst9k
chassis replacement / 7606 / SUP32
Hello friends,
Kindly, I have 7606 chassis with SUP32 IP/MPLS , I want to replace the chassis with same same type so I will turn off the old chassis then plug out the SUP32 from old chassis and plug in to the new chassis then pore on the new chassis.
So once I turn on the new chassis , the service will be recovered normally ?
The new chassis has been tested with SUP720.
Appreciate your feedback.
Ahmed
127
