check leased line BW
hello
please i need to measure the BW of a leased line provided from ISP
i don't need to measure the utilization via whatsup , mrtg  or by transferring file  bla bla bla
i need to measure the actual BW of the leased line that has been provided as when i told the isp to upgrade the BW he said ok but i can't measure it !
Gold
What type of leased line is it ? (i.e  Frame relay, DS-x, Ethernet)
Re: check leased line BW
It's frame relay
Super Bronze
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
What I generally do, is use a traffic generator that can specify different rates.  I'll push one side, intentionally above its rated capacity, I then see whether I get the rated capacity on the other end.
Frame-relay can be a little tricky, because you often can go above CIR, but there's no guarantee of that bandwidth.  If you keep to CIR, you should see that amount on the far side, all without the DE bit set.
Gold
Mr. Doherty has hit the nail on the head (again).
In your case, the capabilities of the physical link are not in play. As long as you can hit the CIR with no DE bits, you are good.
So how i can use traffic generator for a certain link
P.s
My network contains at least 500 remote sites with leased lines how can i measure certain line using traffic generator
Super Bronze
Disclaimer
Posting
Are you using IP?  Are there unique IP ranges on the ends of your different lines?  Then you direct the traffic generator to send traffic to a host IP.
Sure each site has a unique IP
My design briefly
Servers connected to BB -> FW -> core switch -> edge routers -> remote sites
So u mean to install the generator at server ? Can u provide me with a free generator to try it ?
Super Bronze
I guess you could install on a server, but I just run from a client.
I use PCATCP (for Windows).
Many others out there.  Search Internet for free traffic generators.
156
