check router cpu
How do we analyze and calculate the CPU loading of cisco router? enclosed the "sh proc cpu" for your refer. e.g.
interface uses 2% CPU loading
rounting tables 3% CPU loading
or something like.
Any suggestion is welcome
Best regards,
Re: check router cpu
The show processes cpu command output shows the Process which is the nothing but Name of process
Chk this for more infomration
http://www.cisco.com/warp/public/63/highcpu.html#show_process_cpu
Thanks, how do we know the % of service loading?
e.g.
NAT 5% cpu loading
ACL 2% cpu loading
interface I/O 1% cpuloading.
or base on the services
e.g.
Radius authentication: 0.3%
TTY: 0.01%
IP NAT: 5%
etc.
If there is no this info, any idea for me to check the router CPU loading distribution? thanks
Best regard
if you see your output for an Eg
CPU used for last 5 sec is 0.16% last last 1 Min is - 0.10% for last 5 min is - 0.11% by CDP Protocol
hope this Eg helps
Super Bronze
I don't believe you're going to find the level of detail your after, if you're trying to find out how the box is spending its time doing ALL its CPU work. Notice how the software routines don't add up to your 6% in your example. Believe they add up to the delta between the first parameter 6%/6% (although in this case rounding has them shown the same).
The first value of the 6%/6% is the overall load, which is the breakdown I think you're after. The second value is the "interrupt" load, sort of the load imposed by hardware doing primary functions, i.e. switching traffic. Neither of these, I believe, you can resolve to indivual functions.
If you saw something like 25%/5%, you wonder what's imposing the 20% over the "interrupt" load. This is what the % on the individual processes will show.
Thanks for your info. How do we find the abnormal 20% "loading" if it is 25%/5%? Base on the sample file. which one is "interrupt load" and which one is "overall load"? please advice.
Best regards
We try to sum the % (5 sec, 1 min and 5min). the result is not the same as total X% / Y%. Any idea?
Best regards
Super Bronze
Summing the percentages should add to the delta between overall/interrupt, but you don't see those numbers for other than the 5 sec, although you could compute it. E.g.
(sorry, can't control font)
aRouter#sh proc c s
CPU utilization for five seconds: 8%/4%; one minute: 8%; five minutes: 8%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
33 3010540 477114623 6 1.39% 1.44% 1.44% 0 IP SLA Mon Event
5 4004160 370521 10806 0.90% 0.14% 0.11% 0 Check heaps
261 340 573 593 0.49% 0.10% 0.02% 322 Virtual Exec
225 828284 197434399 4 0.32% 0.32% 0.32% 0 IP SLA Mon Respo
78 11271936 25155565 448 0.24% 0.35% 0.36% 0 IP Input
40 182396 3118683 58 0.16% 0.14% 0.15% 0 Per-Second Jobs
244 37520 97293124 0 0.16% 0.17% 0.16% 0 RADIUS
3 287456 2176059 132 0.08% 0.03% 0.02% 0 OSPF-1 Hello
239 11732 31159586 0 0.08% 0.08% 0.08% 0 Mwheel Process
66 5672 12468287 0 0.08% 0.03% 0.02% 0 e1t1 Framer back
11 568 3116984 0 0.08% 0.00% 0.00% 0 IPC Deferred Por
17 868284 2008548 432 0.08% 0.02% 0.00% 0 ARP Input
55 20164 4688886 4 0.08% 0.00% 0.00% 0 mxt5100
240 637884 8559345 74 0.08% 0.06% 0.08% 0 HSRP (Standby)
217 2186980 11375287 192 0.08% 0.23% 0.25% 0 OER Master Contr
15 0 1 0 0.00% 0.00% 0.00% 0 Crash writer
See how the 5Sec column should add close to the delta of 4% (8% - 4%), actually above adds to 4.3.
Does it mean that
X% -Y% = sume of "sort by 5sec" figure? if so, do we focus those "sort by 5 sec" process to solve the issue?
BTW. can we find the cpu loading distribution?
or similar infor? please advise. thanks
best regards
Super Bronze
Yes, believe X% - Y% = sum of "sort by 5sec" figure, or at least close to it.
No, don't think this will solve your issue because Y% is hidden from you.
Super Bronze
Overall load is first value, interrupt the second.
we get the "sh proc output. Anything we can do to reduce the cpu loading? Thanks
Best regards
CPU utilization for five seconds: 25%/15%; one minute: 68%; five minutes: 42%
175 108730948 655701093 165 2.94% 0.50% 0.18% 0 IP SNMP
177 126200092 328032633 384 2.04% 0.40% 0.21% 0 SNMP ENGINE
69 179883224 875132455 205 1.39% 0.39% 0.44% 0 IP Input
176 29505828 327721843 90 1.06% 0.20% 0.04% 0 PDU DISPATCHER
156 1409947241094637462 128 0.90% 0.27% 0.33% 0 DSMP
147 127904432 4502360 28408 0.57% 0.56% 0.54% 0 Compute load avg
128 119806924 101963338 1175 0.57% 0.48% 0.50% 0 CCH323_CT
161 2930303321312172298 223 0.40% 0.34% 0.56% 0 VOIP_RTCP
29 46662308 66438608 702 0.08% 0.22% 0.17% 0 Net Background
158 7913064 44524362 177 0.08% 0.01% 0.00% 0 TSP
61 80929520 44745315 1808 0.08% 0.25% 0.20% 0 ISDN
11 0 2 0 0.00% 0.00% 0.00% 0 RM PROCESS
10 0 2 0 0.00% 0.00% 0.00% 0 RM PROCESS
12 0 2 0 0.00% 0.00% 0.00% 0 RM PROCESS
9 0 2 0 0.00% 0.00% 0.00% 0 RM PROCESS
16 0 1 0 0.00% 0.00% 0.00% 0 AAA_SERVER_DEADT
13 0 2 0 0.00% 0.00% 0.00% 0 CAS Process
14 0 2 0 0.00% 0.00% 0.00% 0 RM-AUTH PROCESS
15 1068 5145 207 0.00% 0.00% 0.00% 0 AAA high-capacit
Super Bronze
HI [PLS RATE if HELPS]
INFO: Total CPU Utilization is comprised of process and interrupt percentages.
Total CPU Utilization: 6%
Process Utilization: 0%
Interrupt Utilization: 6%
These values are found on the first line of the output:
CPU utilization for five seconds: x%/y%; one minute: a%; five minutes: b%
Total CPU Utilization: x%
Process Utilization: (x - y)%
Interrupt Utilization: y%
Process Utilization is the difference between the Total and Interrupt (x and y).
The one and five minute utilizations are exponentially decayed averages (rather
than an arithmetic average), therefore recent values have more influence on the
calculated average.
CPU Utilization is 6% (less than 20%) and there are no problems to report.
Hope I am Informative.
PLS RATE if HELPS
Best Regards,
Guru Prasad R
319
