Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Choosing IOS for 3745
I have a 3745 router that I am going to use for CLNS routing. Currently the router has Rel 12.2(15) ZJ2. This does not support CLNS routing (IS-IS). the main purpose of this router is going to be terminal server access, OSI address routing, and possibly VOIP. What would be the best IOS to load on this router. It currently only has 128mb of DRAM and 64mb of Flash.
Greg
1 REPLY
Re: Choosing IOS for 3745
Hi Greg
I would suggest to use either feature navigator or software advisor tool to find out the exact ios which can fit onto your requirement..
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
http://tools.cisco.com/Support/Fusion/FusionHome.do
regds
107
