Webcast-Catalyst9k
Cisco 1700 Router
I am new to Cisco routing. We have two Cisco 1750 routers that we are not using and I would like to learn more about them. What is the best way to set these up at work and at home to use VPN? Also, The routers have T1 DSU/CSU cards. Do I need to purchase another type of card?
1 REPLY
Hall of Fame Super Bronze
Re: Cisco 1700 Router
Start by reading the documentation
http://www.cisco.com/en/US/products/hw/routers/ps221/tsd_products_support_series_home.html
What type of card are you after ? DSL ?
You should have enough to play at home with the LAN interfaces. For WAN, you can purchase another LAN interface for ethernet connection.
94
