Community Member
Cisco 1720 Point to Point T1 Setup
I am taking my very first stab at setting up a point to point T1 with 2 1720 Cisco routers. We are trying to connect a remote location to our corporate office over a dedicated T1. The remote site uses 10.0.0.0/24 and the corporate site uses 192.168.100.0/24. Both 1720 have 1 T1 wics with intigrated CSUs. Systems on both ends need to be able to communicate with each other. I believe I need to setup both routers as a bridge but I do not have a clue as to what I need to do. Thanks!
1 REPLY
Re: Cisco 1720 Point to Point T1 Setup
Not a bridge. This config is pretty easy, with the hardest part being the DSU configuation. Here's alink to help with that.
http://cisco.com/en/US/products/hw/routers/ps233/products_tech_note09186a0080093c56.shtml#tconfigcommands
Other than that, assign an IP on the serial interface on both ends (must be in same subnet), no shut the interfaces, and basic connectivity should be there (or close).
1839
