Webcast-Catalyst9k
Cisco 1720 router for ADSL
Hi!
I'd like to use my 1720 router for my ADSL connection. I've heard that, there is optional ethernet card with PPPoE support, which i can connect DSL network.
Is it true? Or there is other possibility for that task?
1 REPLY
Re: Cisco 1720 router for ADSL
Hi does your cisco 1720 have an ADSL card installed? If not you need to buy one, you can get them of EBAY for between £120-£160.
The link below will help you once you get the card:
http://www.cisco.com/en/US/tech/tk175/tk15/technologies_configuration_example09186a0080093e66.shtml
96
