09-27-2005 11:59 AM - edited 03-03-2019 10:36 AM
I have three 1721s that have been using a simple ethernet config to access the Internet via my ISP. Now I've added a fourth 1721 and this one was given five static IPs that are "sticky" and thus my connection is now PPPOE.
My question is how do I modify the config below (which is standard across all three 1721s) so that it does the connection via PPPOE? I've been reading around this forum and Googling but thought I'd pose the question here as well.
Thanks in advance and let me know if more information is needed.
Cheers,
Jon
PS - The first three routers are using 12.3, the new router is using 12.4.
<BEGIN_CONFIG>
Using 1964 out of 29688 bytes
version 12.3
hostname router
boot-start-marker
boot-end-marker
no logging console
enable secret
enable password
no aaa new-model
ip subnet-zero
ip dhcp excluded-address 192.168.0.1 192.168.0.9
ip dhcp excluded-address 192.168.0.20 192.168.0.254
ip dhcp pool LANpool
network 192.168.0.0 255.255.255.0
dns-server 206.13.28.12 206.13.31.12
default-router 192.168.0.1
ip name-server 206.13.28.12
ip name-server 206.13.31.12
ip cef
no scripting tcl init
no scripting tcl encdir
bridge irb
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 0/35
encapsulation aal5snap
dsl operating-mode auto
bridge-group 1
interface FastEthernet0
description Internet Connection
no ip address
ip nat outside
speed auto
interface FastEthernet1
description Connection to Wireless LAN
switchport access vlan 26
no ip address
interface FastEthernet2
description Connect to LAN
no ip address
interface FastEthernet3
description Internal LAN Server
no ip address
interface FastEthernet4
description Connection to DMZ
switchport access vlan 99
no ip address
no cdp enable
interface Vlan99
description DMZ
ip address x.x.x.x 255.255.255.248
interface Vlan26
description routed interface for LAN segment
ip address 192.168.0.1 255.255.255.0
ip nat inside
interface Vlan1
no ip address
interface BVI1
ip address x.x.x.x 255.255.255.252
ip nat outside
ip nat inside source list 1 interface BVI1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 x.x.x.x
no ip http server
access-list 1 permit x.x.x.0 0.0.0.255
access-list 1 permit 192.168.0.0 0.0.0.255
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
line aux 0
line vty 0 4
login
end
<END_CONFIG>
09-27-2005 10:35 PM
Hello Jon,
you are using a BVI as the interface pointing to the Internet, I am not sure if you can tie this to the ATM. Is there a specific need to use integrated routing and bridging ?
GP
09-28-2005 08:51 AM
Hi GP,
Thanks for getting back to me. This config represents how SBC set up their DSL at that time (~1 year ago). Now, they use the "sticky" scenario with PPPOE. My thoughts are I need to adjust my config to match something like this:
http://www.dslreports.com/faq/3643
or follow these guidelines for PPPOE:
http://www.linuxhomenetworking.com/cisco-hn/dsl-router.htm
What do you think? Let me know if this clarifies things for you.
Jon
