Cisco 1760 router problem
Any idea why I can not remove the deleted file in flash: ?
R1#show flash:
System flash directory:
File Length Name/status
1 12124968 c1700-ipvoice-mz.123-5d.bin [deleted]
2 12504136 c1700-ipvoice-mz.123-15a.bin
[24629232 bytes used, 8925196 available, 33554428 total]
32768K bytes of processor board System flash (Read/Write)
R1#squeeze flash: ?
<cr>
R1#squeeze flash:
Squeeze operation may take a while. Continue? [confirm]
First create squeeze log by erasing the entire device
%Error squeezing flash (Missing or corrupted log)
R1#sh ver
IOS (tm) C1700 Software (C1700-IPVOICE-M), Version 12.3(15a), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Thu 21-Jul-05 23:43 by dchih
Image text-base: 0x8000816C, data-base: 0x81434990
ROM: System Bootstrap, Version 12.2(4r)XL, RELEASE SOFTWARE (fc1)
ROM: C1700 Software (C1700-IPVOICE-M), Version 12.3(15a), RELEASE SOFTWARE (fc2)
R1 uptime is 3 weeks, 1 day, 14 hours, 46 minutes
System restarted at 19:28:37 NZDT Tue Feb 13 2007
System image file is "flash:c1700-ipvoice-mz.123-15a.bin"
cisco 1760 (MPC860P) processor (revision 0x200) with 59097K/6439K bytes of memory.
Processor board ID FOC06370050 (2079331927), with hardware revision BB67
MPC860P processor: part number 5, mask 2
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
Primary Rate ISDN software, Version 1.1.
1 Ethernet/IEEE 802.3 interface(s)
1 FastEthernet/IEEE 802.3 interface(s)
13 Serial network interface(s)
1 Channelized E1/PRI port(s)
32K bytes of non-volatile configuration memory.
R1#
1 REPLY
Hall of Fame Super Silver
Re: Cisco 1760 router problem
The squeeze operation writes to a log recording what it is doing. For some reason that log is not functioning on this router. I am pretty sure that if you erase flash (as the error message indicates) it will correct the problem and re-create the log.
Rick
421
