Community Member
Cisco 1800
When setting up an 1811 and a 1200AP. I have configured 3 Vlans 1, 11, 21 on the AP and router. With the Vlans being the default-router for 3 DHCP scopes. Is this the best solution or is there a better one?
1 ACCEPTED SOLUTION
Hall of Fame Super Bronze
Re: Cisco 1800
The default-router should be the 1811 router's IP address under each of those Vlan interfaces. Yes - that's the best solution.
Re: Cisco 1800
Community Member
Re: Cisco 1800
My next question would be can I make subinterfaces for Fastethernet 0. ie...
F0.1
F0.2
put the default router ip address to these interfaces. Make the Vlans=no ip address.
I am attaching the configs for my AP and Router. I would like someone to check these for efficiency and VPN LAN access.
Your assistance will be much appreciated.
By the way, I have one WAN IP supplied by DHCP.
298
