08-20-2013 10:42 PM - edited 03-04-2019 08:49 PM
I have two broadband connections from different internet service providers and I dont have a static ip.
I thought to use cisco 1841 for these connections because Cisco 1841 has two wan ports.
If anyone knows how to configure this with 1841 ( I have username and password for both connection) please help me
just try to give me sample configuration.
thank you
08-21-2013 02:40 AM
interface FastEthernet0/0
no ip address
pppoe enable
pppoe-client dial-pool-number 1
this links to dialer interface
interface Dialer0
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1414
no ip mroute-cache
dialer pool 1
dialer idle-timeout 0
dialer-group 1
ppp authentication pap callin
ppp chap hostname abc
ppp chap password def
ppp chap refuse
ip route 0.0.0.0 0.0.0.0 Dialer0
on internal interface
int f0/1
ip nat inside
ip nat inside source list 101 interface Dialer0 overload
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
***Do Rate Helpful Posts***
Jawad
08-21-2013 02:42 AM
interface Dialer0
ip mtu 1492
ip nat outside
encapsulation ppp
Incorrect, should be 1452.
ppp chap refuse
These commands are not needed.
08-21-2013 08:39 PM
Thank you for your answer.
this is only for a single port I need to use the both WAN ports with two different connections is this is possible? I have a HWIC card with my router so I hope to out the both connections via the HWIC is it possible?
If yes please help me
08-22-2013 11:04 AM
track 1 interface Dialer0 ip routing
delay up 30
track 2 interface Dialer1 ip routing
delay up 30
ip route 0.0.0.0 0.0.0.0 Dialer0 track 1
ip route 0.0.0.0 0.0.0.0 Dialer1 track 2
ip nat inside source list 101 interface Dialer1 overload
*** Do Rate Helpful Posts ***
Jawad
09-02-2013 04:30 AM
thanks for your reply again
I tried use both pppoe connections.
If I use this configuration is the dialer 2 interface works as a failover?
is this configuration is correct?
if any thing wrong please help me.
Router(config)#int vlan 1
Router(config-if)#ip add
Router(config-if)#ip address 192.168.100.5 255.255.255.0
Router(config-if)#int dialer 1
Router(config-if)#mtu
Router(config-if)#mtu 1492
Router(config-if)#ip address negotiated
Router(config-if)#ip nat
Router(config-if)#ip nat ou
Router(config-if)#ip nat outside
Router(config-if)#ip virtual-reassembly
Router(config-if)#encapsulation ppp
Router(config-if)#ip tcp ad
Router(config-if)#ip tcp adjust-mss 1412
Router(config-if)#dialer pool 1
Router(config-if)#dialer-group 1
Router(config-if)#ppp authentication chap callin
Router(config-if)#ppp pap sent-username username1 password 0 123456
Router(config-if)#exit
Router(config)#int dialer 2
Router(config-if)#dialer pool 2
Router(config-if)#dialer-group 2
Router(config-if)#ppp pap sent-username username2 password 0 123456
Router(config)#int fastEthernet 0/1
Router(config-if)#pppoe enable
Router(config-if)#pppoe-client dial-pool-number 1
Router(config)#int fastEthernet 0/0
Router(config-if)#pppoe-client dial-pool-number 2
Router(config)#ip dhcp pool test
Router(dhcp-config)#network 192.168.100.0 255.255.255.0
Router(dhcp-config)#default-router 192.168.100.5
Router(dhcp-config)#dns-server 119.235.0.4 203.81.108.4
Router(config)#ip dhcp excluded-address 192.168.100.0.1 192.168.100.20
Router(config)#ip classless
Router(config)#ip route 0.0.0.0 0.0.0.0 dialer 1
Router(config)#ip route 0.0.0.0 0.0.0.0 dialer 2 100
Router(config)#access-list 101 permit ip 192.168.100.0 0.0.0.255 any
Router(config)#ip nat inside source list 101 interface dialer 1 overload
Router(config)#ip nat inside source list 101 interface dialer 2 overload
09-02-2013 09:11 AM
For NAT overload on 2 WAN connections you need to use route-maps :
route-map DIALER1
match ip add 101
match interface dialer 1
route-map DIALER2
match ip add 101
match int dialer 2
ip nat inside source route-map DIALER1 interface dialer 1
ip nat inside source route-map DIALER2 interface dialer 2
2) the the TCP MSS can be up to MTU-40 so here 1452
3) you are doing CHAP authentication but are providing PAP credentials,you should provide CHAP credentials with the ppp chap hostname and ppp chap password commands
Alain
09-02-2013 11:40 PM
Thanks a lot for your reply.
So the remain commands are correct right?
I need only chnge in NAT overload right?
09-16-2013 04:52 AM
Hi thanks for your help,
One more thing I have to ask,
Is failover will work with this configurations? because that's why I placed two different static routes with different AD.
if not help me to config a failover with this 1841 router....
please help me
09-17-2013 01:16 AM
yes failover will work.
Alain
09-18-2013 01:45 AM
Thanks for your replay.
I will try this and let you know
Thanks again.
