02-06-2014 03:21 AM - edited 03-04-2019 10:16 PM
We have a Cisco 1841 DSL router in a remote office set up as a VPN back to out HQ. It has become unrealable over the last few days and te ISP say the line is fine so it must be our router. It has been running for years without issues.
I'm wondering if it is the firmware or modem version, but can you tell anything from this output as I don't uinderstange the noise margins?
show dsl interface atm 0/0/0
ATM0/0/0
Alcatel 20150 chipset information
ATU-R (DS) ATU-C (US)
Modem Status: Showtime (DMTDSL_SHOWTIME)
DSL Mode: ITU G.992.1 (G.DMT) Annex A
ITU STD NUM: 0x01 0x1
Vendor ID: 'ALCB' 'GSPN'
Vendor Specific: 0x0000 0x0008
Vendor Country: 0x00 0xFF
Capacity Used: 98% 110%
Noise Margin: 10.0 dB 10.0 dB
Output Power: 20.0 dBm 12.0 dBm
Attenuation: 46.0 dB 27.5 dB
Defect Status: None None
Last Fail Code: None
Selftest Result: 0x00
Subfunction: 0x15
Interrupts: 2657 (0 spurious)
PHY Access Err: 0
Activations: 1
LED Status: ON
LED On Time: 100
LED Off Time: 100
Init FW: embedded
Operation FW: embedded
SW Version: 3.8131
FW Version: 0x1A04
Show version
Compiled Wed 22-Aug-12 03:36 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
1841 uptime is 25 minutes
System restarted at 10:56:11 utc Thu Feb 6 2014
System image file is "flash:c1841-advipservicesk9-mz.124-25g.bin"
show inventory
NAME: "chassis", DESCR: "1841 chassis"
PID: CISCO1841 , VID: V04 , SN: FCZ111020RF
NAME: "WIC/HWIC 0", DESCR: "WAN Interface Card - ATM (With ADSL module)"
PID: WIC-1ADSL= , VID: 2.3, SN: FOC11056U1U
02-06-2014 04:36 AM
Hello
If you say nothing has changed on either side of this connection, So then looking at your post the unitization on the link seams its maxing out?
I dont know what the noise average should be maybe someone else be able to comment,but as I can see no defects are being reported also.
Do you having any crc error etc? .
Please don't forget to rate any posts that have been helpful.
Thanks.
02-06-2014 05:09 AM
Hi Andy,
Try changing RJ11 and splitter as they tend to degrade overtime.
Ask your ISP for an onsite visit if still persists.
