05-17-2014 12:49 PM - edited 03-04-2019 11:00 PM
I have a cisco 1841 router I brought home for the weekend to play with from work. I set it up at work just fine with a static ip from my isp. However at home I don't have a static ip. I got it all configured and set interface fastethernet 0/0 as my wan and set the ip address to dhcp. I have nat turned on as well. I set up fastethernet 0/1 as my lan. I also setup a ACL to permit any and overload on fastethernet 0/0. from the router I can ping www.google.com and 8.8.8.8 and get responses. On my computer however I cannot get responses. I can however ping the router. What am I missing?
Current configuration : 911 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no logging console
no aaa new-model
dot11 syslog
ip cef
archive
log config
hidekeys
interface FastEthernet0/0
ip address dhcp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.10.1.253 255.255.255.0
ip nat inside
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
no ip http server
no ip http secure-server
ip nat source list 1 interface FastEthernet0/0 overload
access-list 1 permit any
control-plane
line con 0
line aux 0
line vty 0 4
login
scheduler allocate 20000 1000
end
Thank you
05-17-2014 01:45 PM
What is the IP settings of your desktop/laptop? It should point to the router as default-gateway then you could point the DNS to your ISP DNS server.
05-17-2014 04:11 PM
i tried setting my desktop with a static and no luck with the dns server set to the router. I also tried 8.8.8.8 as the dns server with no luck.
05-17-2014 05:48 PM
hi,
try this:
no access-list 1 permit any
access-list 1 permit 10.10.1.0 0.0.0.255
05-18-2014 11:48 AM
I tried to configure this over a lab and I was able to get positive results with ACL 1 set to any but you may still want to try johnlloyd_13's suggestion.
However, what I tried to do in my lab is to set the customer facing interface of the ISP to no ip proxy-arp since your default route is just pointing out to exit interface. When I turned on proxy-arp on the ISP router then I was able to ping anything on the ISP side. Apparently, you have mentioned that ICMP from the router works fine so we could eliminate proxy-arp issue at the ISP side.
What I can suggest is to turn on NAT and ARP debug to see if you are translating your internal network properly.
05-18-2014 03:22 PM
I figured out my issue, on the ip nat source list 1 interface fastethernet 0/0 I didn't type in inside. I also fixed my ACL to be more specific.
Thanks for the help!
