08-03-2012 11:07 AM - edited 03-04-2019 05:09 PM
I have a cisco 1841, here is a snippit of my config..
ip nat inside source static tcp 10.20.36.12 3389 interface FastEthernet0/1 4389
ip nat inside source route-map NAT interface FastEthernet0/1 overload
ip nat inside source static tcp 10.20.36.249 22 interface FastEthernet0/1 22
ip nat inside source static tcp 10.20.36.249 23 interface FastEthernet0/1 23
I would like to open the terminal services port 3389 on 10.20.36.12 FROM OUTSIDE using port 4389.
It woud seem that I have the proper syntax? But when trying to change the direction to FROM OUTSIDE TO INSIDE, i am unable to. have I missed something critical?
Should I be holding a WRONG WAY sign..lol
08-03-2012 04:29 PM
Is fe0/1 the external intrface you will be coming in on. If so then your config is good. If not then simply replace fe0/1 with your external interface and job done.
08-03-2012 05:38 PM
I agree with Andrew and don't see any problem with your NAT config. Could you post your show run and show ip nat translation | inc 10.20.36.12? Kindly remove sensitive data.
08-03-2012 09:12 PM
Please post yours running config so that we can understand your outside interface
