Community Member
Cisco 1841 with HWIC-1T
Received the Cisco 1841 two weeks ago and configured the Ethernet Interface just fine.
Received the HWIC-1T serial card today. Powered off and unplugged the 1841, attached wrist-strap and inserted the HWIC-1T into an available slot.
Powered up the 1841 but the HWIC-1T is not being recognized. SDM and CLI are not showing a serial interface, just the 2 Ethernet Interfaces.
Is there something else to be done to the 1841 to recognize this serial card?
Show ver:
wat_framerelay#show ver
Cisco IOS Software, 1841 Software (C1841-IPBASE-M), Version 12.4(3i), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 28-Nov-07 18:17 by stshen
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
wat_framerelay uptime is 30 minutes
System image file is "flash:c1841-ipbase-mz.124-3i.bin"
Cisco 1841 (revision 7.0) with 114688K/16384K bytes of memory.
Processor board ID FTX124920D0
2 FastEthernet interfaces
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
31488K bytes of ATA CompactFlash (Read/Write)
Show interface:
wat_framerelay#show int
FastEthernet0/0 is up, line protocol is up
Hardware is Gt96k FE, address is 0021.a0ee.2d38 (bia 0021.a0ee.2d38)
Description: $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0$$ES_LAN$$FW_INSIDE$
Internet address is 172.16.101.253/16
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:00, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 0 bits/sec, 1 packets/sec
3521 packets input, 293616 bytes
Received 2764 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog
1266 packets output, 187400 bytes, 0 underruns
0 output errors, 0 collisions, 3 interface resets
0 lost carrier, 0 no carrier
FastEthernet0/1 is administratively down, line protocol is down
Hardware is Gt96k FE, address is 0021.a0ee.2d39 (bia 0021.a0ee.2d39)
Auto-duplex, Auto Speed, 100BaseTX/FX
Last input never, output never, output hang never
0 packets input, 0 bytes
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog
0 packets output, 0 bytes, 0 underruns
wat_framerelay#
Community Member
Re: Cisco 1841 with HWIC-1T
I found 1 error in the log:
Slot 0: Unrecognized cookie format for card!
So..is this an IOS version problem? faulty card?
Hall of Fame Super Blue
For these HWIC cards the minimum Cisco IOS Software release required is Release 12.4(20)T or 12.4(23), see platform support section in the following doc -
http://www.cisco.com/en/US/prod/collateral/modules/ps5949/datasheet_c78-491363.html
Jon
3234
