11-15-2010 07:54 AM - edited 03-04-2019 10:28 AM
Dear Sirs/Madam,
We have set the router up as per the ISP's requirements, both serial interface (E1/T1 G703) & protocol are up & we've entered the required WAN ip & subnet etc but we are unable to ping it directly from itself or from outside, any help would be greatly appreciated.
Kind Regards,
kit
Solved! Go to Solution.
11-15-2010 02:29 PM
Try taking the access group off the serial interface in both directions.
If possible, you should be on the console port, ping out to nameservers.
The default gateway should be the "upstream neighbor" of this router, not this router.
11-15-2010 11:38 AM
can you post the configuration of the router?
can you ping the ISP from the 1941 ?
11-15-2010 12:05 PM
Hi, no we cant ping the ISP or any other WAN address. I think it may be due to no specific entries on the ACL? I am trying to add 'permit' to access list 23 (already existed) but cannot add anything to it? When I add the line from 'configure terminal' 'access-list 23 permit tcp any any' its seems to run the command then shows an error 'invalid input detected' & the pointer (^) is on one of the dns entries?
11-15-2010 12:54 PM
Can you post a configuration?
11-15-2010 01:12 PM
boot-start-marker
boot-end-marker
card type e1 0 0
no logging console
no aaa new-model
clock timezone London 0
clock summer-time London date Mar 30 2003 1:00 Oct 26 2003 2:00
no network-clock-participate wic 0
no ipv6 cef
ip source-route
ip cef
ip domain name yourdomain.com
ip name-server 85.189.102.5
ip name-server 85.189.39.5
crypto pki trustpoint TP-self-signed-1461500852
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1461500852
revocation-check none
rsakeypair TP-self-signed-1461500852
quit
license udi pid CISCO1941/K9 sn FCZ1430912B
username admin privilege 15 secret
username admin privilege 15 secret 5 !
controller E1 0/0/0
channel-group 0 unframed
interface GigabitEthernet0/0
description $ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$$ETH-LAN$
ip address 10.10.10.1 255.255.255.248
ip access-group 23 in
ip access-group 23 out
ip virtual-reassembly
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:0
ip address 109.x.x.x 255.255.255.252
ip default-gateway x.x.x.x
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route profile
ip route 0.0.0.0 0.0.0.0 Serial0/0/0:0
ip access-list extended NH
permit tcp any any
access-list 23 permit 10.10.10.0 0.0.0.7
11-15-2010 02:29 PM
11-16-2010 05:20 AM
Excellent! Thanks for your help/advice we are now able to ping/see the out
side world after removing access in/out & setting up the correct gateway.
Kind Regards,
Noaman
