Webcast-Catalyst9k
Cisco 1941 with vwic3-1mft-t1e1 amber light !!!! Help
Hi, I'm assembling a 1941 router with a vwic3-1mft-t1/e1 serial module installed.  As soon as I set the "card type t1 0 0 " command the amber light (AL) appears on the interface.  Is this normal?  I've set the controller t1 0/0/0 to all the t1 defaults but the light remains on.  What am I missing here?  I bet its pretty obvious to the experienced on here but I'm still scratching my head !!! I've tried all the different controller settings to no avail. Please help. Really appreciate your input.  Thx
Running IOS Version 15.2
1 ACCEPTED SOLUTION
Green
Henry.
The LED uses are :-
LEDs
• CD (data carrier detect): Indicates a received error on the telco link
• LP (loopback): Indicates that the interface is in loopback mode
• AL (alarm): Indicates an alarm condition
If the AL LED is amber
You must be seeing an error condition from the following list :-
Alarm detection: Alarm indication signal (AIS), time-slot 16 AIS, remote alarm, far-end block error (FEBE), out of frame (OOF), cyclic-redundancy-check (CRC) multiframe OOF, signaling multiframe OOF, frame errors, CRC errors, loss of network signal (red alarm), loss of network frame, receive (blue alarm) (AIS) from network, receive (yellow) from network performance reports or error-counters CRC, errored seconds, burst errored seconds, severely errored seconds, Ft and Fs framing errors for SF framing, (FPS) framing errors for ESF framing, and 24-hour history stored in 15-minute increments
Have you got your framing set correctly etc.
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
1 REPLY
Green
Henry.
The LED uses are :-
LEDs
Alex.
645
