12-20-2011 07:40 PM - edited 03-04-2019 02:42 PM
Good day. Please advise me if WIC-1B-S/T interface card will work on Cisco 1941/K9 (Cisco 1941 w/2 GE, 2 EHWIC slots, 256MB CF, 512MB DRAM, IP Base). Thank you very much.
12-20-2011 08:18 PM
The specific part number you post is not supported on ISRg2 models. But, you will find that functionality in v3 version of that module.
Please see http://www.cisco.com/en/US/prod/collateral/routers/ps10538/aag_c07_563807.pdf for a comprehensive list of supported modules on ISRg2.
Hope this helps!
_dschlicht
12-20-2011 08:24 PM
Thank you so much for the answer, Sir. It helps.
12-20-2011 08:31 PM
You need the V3.
