Community Member
Cisco 2600 IOS upgrade
I have uploaded new IOS image on my 2600 series router. But now my router doesn't come up.
During uploading image it asked to erase the flash but i given "NO" & uploaded image.Image uploaded successfully. after that i given command " boot system flash imagename".
Write the configuration.
Then reload. But its not coming UP now.
Please help me.
2 ACCEPTED SOLUTIONS
Silver
Re: Cisco 2600 IOS upgrade
I believe there are two reasons :
1) Upload the incorrect image that does not supported by 2600 or the image is crashed.
2) The config-reg. may be correct.
Try to follow below link to boot the router in ROM mode and check corresponding parameters and config. And you can follow the guide to troubeshoot the probelm. The final step is to recovery as password recovery process which is contained in the link.
http://www.cisco.com/en/US/products/hw/routers/ps259/products_installation_guide_chapter09186a008007e022.html
http://www.cisco.com/en/US/products/hw/routers/ps259/products_password_recovery09186a0080094675.shtml
Hope this helps.
Hi Siddesh
Did you check out for the necessary prequistie
(like flash/dram etc.,) before loading the ios code onto the router ?
do check this link out to recover your box from the current state. ..
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a0080094a0b.shtml
regds
Silver
Hope this helps.
Hi Siddesh
regds
Community Member
Thanks for reply.Problem has been resolved .It was going in initial setup mode & bypassing startup-config.I don't know why?. But same has been fixed also with IOS upgradation so that i can use cryptographic features.
Anything which will going to update my knowledge is highly accepted & Expected.
Thanks Again.
307
