CISCO 2600+Serial 0/0+ Unable to ping
megerdin2
Hi i m configuring CISCO 2600 to connect Internet. Thats why I use windows hyper terminal to configure the router.
And thereafter,I can only ping e0/0. But I can't ping s0/0 from hyper terminal.
below is my #sh int s0/0 Output.
admin-5#sh int s0/0
Serial0/0 is up, line protocol is up
Hardware is PowerQUICC Serial
Internet address is 123.49.2.150/30
MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
Encapsulation HDLC, loopback not set
Keepalive not set
Last input never, output 00:00:44, output hang never
Last clearing of "show interface" counters 02:01:29
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/1/32 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 1158 kilobits/sec
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
219 packets output, 50435 bytes, 0 underruns
0 output errors, 0 collisions, 18 interface resets
0 carrier transitions
DCD=up DSR=down DTR=up RTS=up CTS=up
------and here is my #sh run...
admin-5#sh run
Current configuration : 1048 bytes
version 12.2
hostname admin-5
enable secret xxx
enable password xxxxx
ip subnet-zero
ip audit notify log
ip audit po max-events 100
voice call carrier capacity active
mta receive maximum-recipients 0
interface Ethernet0/0
ip address 192.168.110.150 255.255.255.252
ip nat inside
no keepalive
half-duplex
interface Serial0/0
ip address 123.x.x.150 255.255.255.252
no keepalive
interface Serial0/1
no ip address
no ip mroute-cache
shutdown
ip nat pool destiny 192.168.110.1 192.168.110.255 prefix-length 24
ip nat inside source list 7 pool destiny
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0/0
no ip http server
access-list 7 permit any
snmp-server community public RO
snmp-server enable traps tty
call rsvp-sync
mgcp profile default
dial-peer cor custom
line con 0
line aux 0
line vty 0 4
password xxxxxx
login
end
admin-5#
I don't know why i cant ping mysel. and thought something wrong in my configuration....
Can u plz help me
Thanks in advance
7 Replies 7
Danilo Dy
Are you able to ping the router at the other side of the link?
Check the first Q&A in this link and see if it applies to your setup http://www.cisco.com/warp/public/116/fr_faq.html
Dandy
I wonder why the serial interface is configured with no keepalive? With this configured the interface will show as up and up whether or not it is working. What happens if you enable keepalive? If it stays up with keepalive enabled then we need to look in certain directions about why ping is not working. But if you enable keepalive and the interface goes protocol down then we know that there is some problem with the connection and that is why ping fails.
The question from Dandy about whether you can ping the router at the other end is another way to get at the same issue - is the link really working?
Dandy
That is an interesting link. But I wonder why you sent a link about problems with Frame Relay when this interface is clearly configured to use the default encapsulation of HDLC (and mapping is not an issue with HDLC)?
Rick
Rick
Hi Rick,
Because it mentioned HDLC and also it says that the router in the other end will reply to the ping. Thats why I ask if he can ping the router in the other end.
"Pings to your own interface address are successful on point-to-point subinterfaces or high-level data link control (HDLC) links because the router on the other side of the link returns the ICMP echo and echo reply packets."
Dandy
Dandy
Thanks for the clarification. I missed the reference to HDLC in the link. The explanation is quite correct that ping on a point to point link is sent over the link (received by the remote router and forwarded back over the link by the remote router) and the ping response is also sent over the link (and received and forwarded by the remote router). The result is that the ping to your own address makes 4 trips over the link while ping to the remote address makes 2 trips over the link.
I agree that your question about whether he can ping the remote router is a key step in investigating this problem.
rick
Rick
Hi Rick,
The "no keepalive" that you mentioned in the interface may be a problem also. But I'm not sure if with it and the router in the other end is down (or NTU), his router interface status will still show up/up - I haven't tried or experienced it.
Dandy
Dandy
With HDLC a router sends a keepalive message and inside that keepalive message is a field (a sequence number) that the remote router should save and send back in its own keepalive. So if this router is working and the remote router is down, then the sequence number will not be returned and the keepalive will fail, and the interface will go to protocol down state. I have tested this many times and the HDLC keepalive is quite reliable about assuring that there is 2 way traffic over the link.
Rick
Rick
Hi Rick,
Thanks for the info. I was thinking to mention it in my first post as reply to his question but since I can't be too sure I didn't mentioned it :).
Dandy
