Community Member
Cisco 2600 Series Routers & chassis serial number
All,
Is there a command that will show the chassis serial number of 26XX router?
Been looking and can't seem to find one.
Thanks in advance.
GH
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Cisco 2600 Series Routers & chassis serial number
sorry, the answer is the same as for the 2500: no.
The reason is because these older routers do not have a memory programmed at factory with such data.
The small routers that do have, are the new generation ISRs, and of course the large ones.
1 REPLY
2064
