Cisco 2600 WIC
Hai, Let me know if cisco 2600 series WIC can be used in Cisco C3845-IPBASE-M router.
it is urgent.. plz.
1 ACCEPTED SOLUTION
Re: Cisco 2600 WIC
Your WIC-1T is supported in the 3845 ISR.
Martin
Re: Cisco 2600 WIC
It depends on what kind of WIC it is. Please confirm.
Martin
Hall of Fame Super Blue
Re: Cisco 2600 WIC
Sorry Martin, cross-post. I'll leave this one with you :-)
Jon
Re: Cisco 2600 WIC
Hardware is PowerQUICC MPC860
Re: Cisco 2600 WIC
Is there a paricular WIC you are interested in - can you send the part number.
Jon
Re: Cisco 2600 WIC
Hardware is PowerQUICC Serial
Re: Cisco 2600 WIC
Re: Cisco 2600 WIC
I believe this may just be a componant of the card you are refering to. If you look at the front of the card where this interface / interfaces are in the top corner you should have a Cisco part code such as WIC-1T, or WIC-1B-S/T.
Martin
Re: Cisco 2600 WIC
Hai Martin,
yes it is WIC-1T..
A.Chenthilkumar
Re: Cisco 2600 WIC
Martin
317
