CISCO 2620
Hi, I had a Router cisco 2620 with a T1 card, I like to upgrade this Router, but not sure witch model select.
I was thinking in a one form the 2800 family. Please give me your recomendations
thanks
  • WAN Routing and Switching
Hall of Fame Super Bronze
Re: CISCO 2620
Javier,
I recommend going with the 2821. It gives you Gigabit LAN capabilites. Very useful if you want to segment 2 LANs via this router.
If budget is a problem, the 2811 can also be a contender.
Re: CISCO 2620
Thanks for the advice, no the budget is not a problem.
Re: CISCO 2620
Is it possible to provide Gigabit LAN (not WAN) capability on 2811? Would it give me Gigabit LAN if I stick in HWIC-1GE-SFP with GLC-T in there? Or is it strictly for Gigabit WAN uplinks?
268
