Webcast-Catalyst9k
Cisco 2621 and WIC-1DSU-T1-V2 incompatibility
It's seems that the Version 2 of the DSU/T1 wic is not working on Cisco 2621 classic. I tried with 3 different IOS, 2 routers and 2 WIC-V2.
I always got the unrecognized WIC error messages. The Cisco documentation stipulates that IOS 12.2(15)ZL is the "minimum requirement" for WIC-V2 to work on Cisco 2600. Is this a known issue? Anyone have experienced this problem? Or does anyone know a Cisco 2600 IOS version that support the WIC-1DSU-T1-V2 (tested/verified)?
IOS TESTED :
12.1(5)
12.2(32)
12.3(15b)
WHAT I GOT FROM CONSOLE PORT :
System Bootstrap, Version 12.1(3r)T2, RELEASE SOFTWARE (fc1)
Copyright (c) 2000 by cisco Systems, Inc.
C2600 platform with 32768 Kbytes of main memory
program load complete, entry point: 0x80008000, size: 0x757d28
Self decompressing the image : #################################################
OK]
Smart Init is enabled
smart init is sizing iomem
ID MEMORY_REQ TYPE
0000A2 0X00103980 C2600 Dual Fast Ethernet
0X00098670 public buffer pools
0X00211000 public particle pools
TOTAL: 0X003ACFF0
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Rounded IOMEM up to: 4Mb.
Using 12 percent iomem. [4Mb/32Mb]
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
IOS (tm) C2600 Software (C2600-I-M), Version 12.3(15b), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Thu 25-Aug-05 13:38 by ssearch
Image text-base: 0x80008098, data-base: 0x80CD9220
cisco 2621 (MPC860) processor (revision 0x600) with 28672K/4096K bytes of memory
Processor board ID JAD054906ZL (2914911530)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
2 FastEthernet/IEEE 802.3 interface(s)
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
Press RETURN to get started!
Unknown WIC in slot(0/0), wic card has an unknown id of 0x52
*Mar 1 00:00:08.535: %LINK-3-UPDOWN: Interface FastEthernet0/0, changed state to up
*Mar 1 00:00:08.535: %LINK-3-UPDOWN: Interface FastEthernet0/1, changed state to up
*Mar 1 00:00:09.227: %SYS-5-CONFIG_I: Configured from memory by console
*Mar 1 00:00:09.711: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0, changed state to down
*Mar 1 00:00:09.711: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/1, changed state to down
*Mar 1 00:00:11.087: %LINK-5-CHANGED: Interface FastEthernet0/1, changed state to administratively down
*Mar 1 00:00:11.507: %SYS-5-RESTART: System restarted --
*Mar 1 00:00:11.507: %SNMP-5-COLDSTART: SNMP agent on host Router is undergoing a cold start
*Mar 1 00:00:12.391: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0, changed state to up
Router>
1 REPLY
Re: Cisco 2621 and WIC-1DSU-T1-V2 incompatibility
You are installing the V2 card in Cisco 2621 which doesnt support the same.
As per Ciscos supporting doc 2600XM series boxes does support the same..
These are the boxes which support the card..
1700(1) (1720, 1721, 1751, 1760), 2600XMs, 2691, 3631, 3725, 3745, and ICS 7750
http://www.cisco.com/en/US/products/hw/modules/ps3129/products_tech_note09186a0080093d70.shtml#supp_platforms
regds
881
