10-27-2010 08:05 AM - edited 03-04-2019 10:16 AM
http://www.facebook.com/CiscoSupportCommunityHi,
This question came from our CSC Facebook community.
10-27-2010 08:48 AM
Dynamic ip alias is created by the router for nat translations. It allows the router to respond to arp requests for IP addresses not physically configured on the router.
For example you may have something like
ip nat inside source static 172.16.1.1 10.221.125.90
you could also have this overloaded using a acl or as part of a pool.
The only way to get rid of this dynamic entry would be to remove the configuration that would cause it to be added. Check your config for nat pool or nat statement that would contain this address or the subnet it would belong to.
David Aicher
10-31-2010 01:22 AM
I checked all 6 routers for this possible ip address and nat configuration , but it was in vain.
is there any aother possibility. pls help
10-31-2010 01:10 PM
On the device that reports that address capture the following
show ip nat translation | inc 10.221.125.90
show run | inc 10.221.125
for that address to show up in "show ip alias" it has to be in some config on that router.
Dave Aicher
